Rear Taper Bearings Spacer?
3 replies to this topic
#1 Tornado99
Tornado99
  • 750 posts
Posted 25 October 2020 - 10:12 PM
Do the taper kits sold by MiniSpares etc need an additional spacer piece per axle or are the races extended to not require it?
My car currently has ball bearing sets in the back and the races extend quite a ways out from the ball cage...no separate spacer is present.
The roller bearing kit I have measures 20.3mm end to end of inner race. Do I need to order a spacer piece?
Edited by Tornado99, 25 October 2020 - 10:27 PM.
#2 Ethel
  • 26,791 posts
Posted 25 October 2020 - 11:23 PM
It'd be included in the bearing kit, but looks like it's been built in to the bearings, same as the ball type.
#3 Tornado99
Tornado99
  • 750 posts
Posted 26 October 2020 - 12:57 AM
What I have looks very much like this:
http://www.minispare...0/GHK1548MS.jpg
Is that what the built-in race spacer looks like?
Edited by Tornado99, 26 October 2020 - 12:58 AM.
#4 nicklouse
  • 19,058 posts
Posted 26 October 2020 - 08:45 AM
If they need a spacer they will come with one. If the don’t need one they will not come with one.
the Minis all used to come with sets that used a spacer. Later when the metro started using the ones with the built in spacer design Minis often got them as well. Note that the Metros only used ball type bearings as the wheel design meant the loads on the bearings was less.
