Where To Obtain Heat Shields To Defelct The Catalyst Heat?
3 replies to this topic
#1 Johnmar
Johnmar
  • Just Joined
  • 176 posts
Posted 26 October 2020 - 10:26 AM
Hi all,
I'm planning ahead for my full restoration. My heat shields are looking tatty, but nowhere I look, they seem to have in stock, the heat shields to install under the floor to deflect the heat from the catalyst .
(part numbers WEB10057 (catalyst) and WEB101440 (exhaust))
Is there an alternative that I can utilize?
#2 vx220
vx220
  • 419 posts
Posted 28 October 2020 - 11:19 AM
If if comes down to it, you can get universal heat shield materials from Demon Tweeks etc
#3 humph
humph
    How bad can it Be?
  • 1,125 posts
Posted 28 October 2020 - 02:15 PM
As above, haven't seen them for sale but you can buy flat sections for DIY bending.
https://www.carbuild...OgaAiltEALw_wcB
#4 brivinci
brivinci
  • 1,225 posts
Posted 28 October 2020 - 06:23 PM
I'd imagine the modern stuff is even better then what was used 25+ years ago. Just make sure its the stiffer/formable type. The original (which I have) is literally just shaped around the tunnel, with the outer most sections bend flat to marry up to the flat portion of the floor it bolts to.
