Hi,
My Mini engine sounds like it is running on 3 cylinders.
I recently replaced the timing chain and gears which is on another thread here but that shouldn't be related I don't think because other than a tappety noise it has been running great with heaps of power.
I checked and changed the plugs. All have spark. I have a new electronic dizzy and coil which was installed before things went a amiss.
The head is fully recond about 6 months old which I did have a head gasket problem at first when I first put the new head on but I flattened out the block with a stone and put the best new head gasket available for a 998 and this seemed to have fixed that issue.
There is no oil in the coolant or coolant in oil but I did notice a slight milky film on the rocker cover cap, no where else in the rocker cover.
Also their is a fair bit of smoke blowing out of the crankcase vent which on my motor is attached to one of the tappet side cover plates.
Any ideas or thoughts of what I should do?
I'm thinking I just wasted 2 grand on a old 998 when I should have been looking for a second hand 1275?
Brad
