Should I see the old, dirty grease coming out somewhere? Thanks!
How Do I Know When I've Pumped Enough Grease Into The Rear Suspension?
Posted 05 November 2020 - 04:31 PM
Posted 05 November 2020 - 04:43 PM
Yes, old grease should come out at least one side of the pivot.
However, if the tube connecting the inner and outer bearings has split then you may have to fill up the hollow trailing arm before grease comes out.
Posted 05 November 2020 - 05:12 PM
Thanks - that's a lot of grease!
Posted 05 November 2020 - 06:05 PM
Provided the grease tube hasn't split. You'll get the grease squeezing out at the opposite end of the radius arm. If it looks like clean grease you can stop injecting. That's the guide I use.
Edited by MikeRotherham, 05 November 2020 - 06:10 PM.
Posted 05 November 2020 - 07:18 PM
Posted 06 November 2020 - 08:12 AM
I'd use something like this in your grease gun:
https://www.amazon.c...,aps,162&sr=8-4
Any reputable make would do as well though.
Posted 06 November 2020 - 08:26 AM
I used this one (same grease as Mike's but in a different container - there's a disk with a hole in these containers that makes it easier to fill some grease guns).
https://www.amazon.c...0?ie=UTF8&psc=1
Posted 06 November 2020 - 10:09 AM
If anyone is interested the aluminium tubes for the radius arms are available from Japan
Posted 06 November 2020 - 03:52 PM
Yep, it sure is - and it comes out round the pivot bolt for the handbrake cable quadrant too.
