Mpi Thermostat Sandwich Plate
5 replies to this topic
#1 wilsonch
wilsonch
  • 107 posts
Posted 22 November 2020 - 09:32 AM
Has anyone come across this problem
I have need of a new thermostat sandwich plate due to corrosion on the mounting faces.
When i look at mini spares their Mpi specific sandwich plate the description says the temp transmitter thread is 12mm.
However the current (original) plate isn't 12mm thread regular or fine.
The sensor is an Elmwood ES120-4 (light brown connector.)
Do i just have to suck it up and buy a new sensor as well as the plate?
Chris
#2 GraemeC
GraemeC
  • 7,314 posts
Posted 22 November 2020 - 10:59 AM
Could you buy one of the undrilled ones and tap it yourself?
Google says the Elmwood ES120-4 is M12x1.5
Edited by GraemeC, 22 November 2020 - 11:05 AM.
#3 nicklouse
  • 17,944 posts
Posted 22 November 2020 - 12:57 PM
Just measured my genuine MPI sandwich plate.
M12x1.5.
#4 wilsonch
wilsonch
  • 107 posts
Posted 22 November 2020 - 03:23 PM
Thanks gents.
I did try my m12 1.5 die on the sensor which tightened up after the first turn and a tap in the plate and the same thing happened and i began to doubt myself.
I will get a plate and 'hope' the sensor fits. After your reassurance i am sure it will.
Thanks.
#5 nicklouse
  • 17,944 posts
Posted 22 November 2020 - 03:27 PM
Thanks gents.
Thanks.
Are you sure the die is 12x1.5? The standard pitch for M12 is 1.75.
Edited by nicklouse, 22 November 2020 - 03:27 PM.
#6 wilsonch
wilsonch
  • 107 posts
Posted 23 November 2020 - 03:33 AM
Yeah i have both 1.5 and 1.75.
1.75 is standard but a standard m12 nut wont thread onto the sensor either. (this is the first thing i tried.)
You can see its a finer thread when you offer up a standard bolt to the sensor.
My confusion was that mini spares just says m12 thread for the thermostat sandwich plate. It doesn't say m12 fine thread or m12 x 1.5thread.
Edited by wilsonch, 23 November 2020 - 03:34 AM.
