My boots been leaking worse than a cabinet meeting at no 10 recently so i decided to replace the boot seal. After ordering the wrong one first , i today tried fitting the correct one, for a 1989 model- I think !
Tried fitting one from minispares, used wd40 to help it slide into place, but boot just won't shut now- i tried trimming bits of the lower edge as this seemed to be the problem, but to no avail. So I've had to put the old one back on. Whats the secret ?
Any tips ?
Are some suppliers seals better than the others ?
Do you need to soften it up in hot water first ?
Is there a right and wrong way round ?
I did feel that this particular seal looked slightly larger when viewd in a cross section, but i suppose that could be due to ther shrinking with age
thanks in advance for any advice !
