The front section has fitted perfectly to the Spi manifold, the cat should then fit with a gasket, then the twin box RC40 back end should fit to the back of the cat with no gasket - it has a tapered end which doesn’t use a gasket.
However ... there’s an arrow on the cat that would suggest the way round it should be fitted, arrow in the direction of flow, but that means the tapered connection on the cat is at the front not the back. Am I missing something, or is there a possibility my cat has been assembled wrong?
The photos show:
- the RC40 tail section with the plain end of the cat;
- the RC40 tail section with the tapered end of the cat;
- the arrow on the cat ... which points towards the plain end.
