Respray problem
Posted 03 November 2006 - 10:47 AM
I've just started to respray my mini but I have a problem. I have started by spraying primer over the existing paint which has been wet and dry sanded to get a key and then panel wiped. However, on applying the primer I can see that in areas there are still small white dots (the original colour) where the primer has not adhered properly and sometimes this can be seen as long white rods. It looks like germs/amoebas in a petri dish surrounded by a grey dye :'(
I guess it's something simple perhaps I'm not leaving the panel wipe long enough to evaporate but the surface seems pretty dry to me -so any other ideas?
Any help appreciated,
spud.
Posted 03 November 2006 - 11:34 AM
you might find you have missed a couple of tiny areas when wet sanding, so there is still some glossy paint in some areas, rub the primer back and try flatting that area back again, then degrease thoroughly, and then try respraying...
Posted 03 November 2006 - 12:15 PM
Posted 03 November 2006 - 12:26 PM
Strangely enough, I've just primered the roof and it's gone on very well with exactly the same preparation.
Though when I think about it I probably spent a tad more time sanding the roof than any other area. As suggested, if I flat down the problem areas again and respray it then hopefully the problem might be cured. Although now I come to think, there is an area in the boot which got a lot less attention and its gone fine.
I'll try to post a pic if I can.
Thanks for your help
Cheers,
spud.
Posted 03 November 2006 - 01:20 PM
it could also apart from the above suggestions be too much thinners in the primer.
Posted 03 November 2006 - 02:20 PM
I'll check more accurately next time.
spud.
Posted 03 November 2006 - 07:10 PM
Posted 03 November 2006 - 07:31 PM
Though I have gone over again the areas to spray.
I got a wonderful finish on the roof not bad for a complete novice
By the way, what is 'scotching'
Cheers,
spud.
Posted 03 November 2006 - 08:18 PM
Thanks for all the replies - I've taken note of all your inputs, I think the problem was that the primer to thinners ratio was too weak a mix.
Cheers,
spud.
its like the green square pads you use to clean the dishes with
Posted 04 November 2006 - 12:06 AM
Posted 04 November 2006 - 08:54 AM
Posted 05 November 2006 - 05:47 PM
any decent paint supply shop will stock scotchbrite its a 3m product
gaz
Posted 06 November 2006 - 10:41 PM
Posted 07 November 2006 - 10:37 PM
spose those sorta things are second nature, so i forget
gaz
Posted 10 November 2006 - 07:04 PM
Also when you flat the paint down wet , use a de-greaser in the water as this cleans as you flat down (we use washing -up liquid )
does it matter which sort ?
or is fairy the best with longer lasting bubbles
Edited by LITTLE MISS NAUGHTY MINI, 10 November 2006 - 09:58 PM.
