YES and it leaves my hands "fairy soft"
Also when you flat the paint down wet , use a de-greaser in the water as this cleans as you flat down (we use washing -up liquid )
does it matter which sort ?
or is fairy the best with longer lasting bubbles
Respray problem
#16
Posted 11 November 2006 - 08:32 AM
#17
Posted 11 November 2006 - 03:00 PM
all the better for touching my car
#18
Posted 15 November 2006 - 05:08 PM
Personally I'd advise against using washing up liquid.
#19
Posted 15 November 2006 - 10:11 PM
You only use a small squirt to a 2 gallon bucket and it is rinsed afterwards , been using it for 30 years now ,
it is never used on bare metal, and you dont respray your car very often do you ? , it is not like washing you car every week in washing up liquid , it is a very effective at de-greasing (ok there is a special de-greaser you can buy to add to your bucket and it is probs more suited to the job but everywhere i have worked use washing-up liquid)
however DO NOT USE CAR SHAMPOO as this contains wax and additives (not contained in washing up liquid)
SO do as you want on your car BUT please dont go around giving advice on things you know nothing about !!! >
Edited by Woody, 15 November 2006 - 10:39 PM.
#20
Posted 15 November 2006 - 10:48 PM
NOOOOOOOOOOOOOooooooooooo!!! Don't use fairy liquid!! it contains salt, therefore is corrosive!
What caused your spots in the paint (the technical term is "fish-eyes") is probably sillicone contamination. Oil or other contaminants will cause a similiar affect. Make sure you thoroughly degrease and panelwipe the whole car, as most cars have layers of polish on top of the paint, this usually contains sillicones. So basically you are trying to paint ontop of a thin layer of sillicone! And when I say degreaser, I mean proper degreaser, don't get this confused with panelwipe which is 90% water and is not much use at removing stubborn stuff. I use cellulose thinners as an initial degreaser, but be careful if you do this, it can melt the paint if you leave it on for too long!! not pretty. Anyway good luck!!
#21
Posted 15 November 2006 - 11:06 PM
Am very sorry. I have no problems admitting you are more experienced than me, however, from the post above it looks like my post has just been backed up by someone else in the industry.Dear Mr Jammy B
#22
Posted 15 November 2006 - 11:07 PM
PLEASE READ POST ABOVE
be verry carefull about using thinners to de-grease as it can soak into the existing paint causing it to soften and cause reactions in the next layer of paint applied
