Cams....
#16
Posted 22 August 2004 - 06:50 PM
how much is engine wear increased? and on what parts?
is the performance increase enough to justify this greater wear?
Kane
#17
Posted 22 August 2004 - 08:47 PM
Reading an artical in the tech section of Mini Mag (the one with the 8 port cluby on the front) it says that small bore engines dont benefit from roller rockers and that a cam on its own is enough, any more lift and it starts to loose power.
#18
Posted 22 August 2004 - 10:44 PM
#19
Posted 23 August 2004 - 09:11 AM
#20
Posted 24 August 2004 - 12:28 PM
#21
Posted 24 August 2004 - 12:36 PM
Both bushed and arms with bearings have the same adjusting screw at the rear. At the front the hardened contact pad is replaced with a ball bearing or annular ring. As the arm actuates the valve the bearing/roller ring rolls across the top of the valve stem. This rolling action prevents the side loads mentioned earlier which accelerate valve guide wear. The cheaper arms use bushings for the fulcrum just like standard rocker arms. The more expensive arms replace the bushes with needle bearings.
High-lift arms move the position of the fulcrum back towards the adjusting screw and must be used with compatible rocker shaft pillars which move the whole rocker shaft to the rear.
#22
Posted 24 August 2004 - 06:24 PM
#23
Posted 24 August 2004 - 10:39 PM
#24
Posted 25 August 2004 - 05:31 PM
not quite, it moves the valve further in the same amount of time, the duration does not change, only the lift and velocity/acceleration of the valvehigher ratio rockers also open the valve a little earlier and closes it a little later .
#25
Posted 25 August 2004 - 05:41 PM
It is worth it, there is not much more added wear espeically with roller tip rockers there is even less as mentioned in previous posts.when fitting these higher lift cams and greater ratio rockers ....
Kane
Performance increase is good and even beetr with other modifications as flowed head and stg1 kit. These work together to give even more power. As long as the engine is looked after then wear isnt much quicker although it would be advised on a full rebuild while the engine is out and the cam is going in!
Something else too to think about is cam timing! verneir gears are needed for accurate timing set up especailly on modified cams! so add that onto the cost. Personally i think it is worth it, to feel the power kick in feels great though over do it on the duration and u will be pulling away from the lights at 3k rpm just so that u dont stall it
#26
Posted 25 August 2004 - 09:17 PM
#27
Posted 25 August 2004 - 10:29 PM
#28
Posted 26 August 2004 - 09:32 AM
As far as ware goes on these engines I have never got much more than 25000 miles from one without a total rebuild. It depends how you drive. With the 276 cam in a 998 it will not pull until about 3000rpm, and when i say not pull I mean no power at all. Then after 3000 rpm it will go very nicely upto about 7000rpm if the head is upto it. If you are the sort of driver (as I am) that loves to rev it between each gear then don't expect it to last long. Revs kill engines, but to get power from a small cc engine you have to rev it......
#29
Posted 26 August 2004 - 08:45 PM
im on less than that working at halfords and 18 and a uni student nowexactly why im getting a job that pays more than 5 pound an hour (being 16 money does become small)
#30
Posted 26 August 2004 - 09:28 PM
i will definitley bear that in mind, thanks ben h
