Spraying the rocker cover
Posted 24 November 2006 - 08:19 PM
Posted 25 November 2006 - 12:20 AM
Posted 25 November 2006 - 12:23 AM
so long as you prep it right, most paint will stick to it. hammerite spray is pretty good if you take your time, and halfrauds own brand stuff is ok, so long as you put lacquer on it.
Ok cool.
When you say prep it, i know what u mean, but spraying something lke that, what way would u prep it.
Could you give us little run down. plus the best way to do the lacquering as well
Thanks.
Posted 25 November 2006 - 12:31 AM
degrease it with thinners or something so you dont soak your sandpaper in oil. rub down the exterior with wet and dry till its all nice and smooth (you could nitromors it off and start with bare steel as well). degrease it again to be sure. I just use halfords spray cans, get one of primer, one of the colour you are using and one of lacquer. Its not cheap but its good stuff, and its compatible with the halfords paint. give it 2 or 3 thin coats of primer, when its dry rub it down with wet and dry. then give it about 4 thin coats of colour. flat this down with wet and dry when its dried off, and give it one final coat of colour. When this is dry, give it some thin coats of lacquer. It should come up looking very shiny!
Posted 25 November 2006 - 12:37 AM
lol I'm no expert! I'll give it a go though....
What numbers on the wet and dry am i looking at ?
Do u just use normal car spray primer. then the hammerite spray on top.
Plus, whats nitromors. do u just soak it. and would it come up new looking..
Oh thats that paint striper stuff that stuff burns when u get it on ya hands lol
Edited by Mark1275GT, 25 November 2006 - 12:43 AM.
Posted 25 November 2006 - 12:50 AM
Posted 26 November 2006 - 10:42 PM
Mark,... try searching for the answer to your question using the search function on the site., almost all paint questions at some point have been answered and i'm pretty sure you'll find lots of useful information
search for 'Prep' and you'll be astounded by the amount results
Edited by Retro_10s, 26 November 2006 - 10:42 PM.
Posted 26 November 2006 - 11:16 PM
800grit to flat the primer, 1200 used lightly for the colour.
Okie dokie.
Posted 26 November 2006 - 11:46 PM
Posted 26 November 2006 - 11:55 PM
i just nitromors'ed mine (just brush it on, leave and hour and then scrape/wire brush off.. although you will need 2 or 3 goes at it to get it really stripped). then normal halfords primer and car paint. Its come up quite nice....
Car paint ? i thought it would peal off after a sort time.
Wouldnt hemmerite spray be better or not ?
This is mine. looks worse in person.
Its steal
Edited by Mark1275GT, 26 November 2006 - 11:57 PM.
Posted 26 November 2006 - 11:59 PM
Posted 27 November 2006 - 12:13 AM
Posted 27 November 2006 - 12:31 AM
Posted 27 November 2006 - 12:41 AM
thats some crazy steel if it is
Well that what i was told. lol
On the left of the rocker cover, it has had a pipe welded onto it, which is for the Catch can. didnt think things could be welded to ally. guess not lol
Anyway.
It has alot of black spots on it, which is hard to get off. so i guess ill have to spray it.. well try anyway.
First time
Posted 27 November 2006 - 10:27 AM
Spaying the rocker cover
Poor Rocker Cover...
