Here's what i would do if i was using car paints with a laquer coat too.
1. Prep the rocker cover by rubbing down with 600grit wet and dry.
2. Degrease and wipe down the rocker cover using white spirit.
3. Spray 2 light coats of primer, allow them to FULLY harden. (see primer instructions)
4. Flat back the primer layers just to get it smooth with 800grit wet and dry till smooth.
5. Spray another 2 coats of primer on and let them FULLy harden.
6. Flat back the layers of primer with 1200grit wet and dry till nice and smooth.
7. If any patches are primer-less after flatting back, keep adding coats till you can flat it back and still have a fully layer on.
8. Degrease using white spirit, when completely dry, add your first 2 light coats of colour and allow to harden
9. Flat back Using 1200 wet and dry. Add another two coats and allow to fully harden.
10. Flat back using 1200 wet and dry. Now degrease the rocker cover.
11. Now add a couple of light layer of laquer and let them dry fully.
12. Now flat the laquer back lightlywith 1200grit wet and dry.
13. Add another two coats of laquer and allow it to harden fully.
14. Flat it back lightly, Now using cutting paste on a 'moist' cloth,.. cut the laquer back.
15. Using T-cut/or similar polish it back up! leave it for a week in a warm enviroment (indoors)
16. Now wax it!
Right. A quick note to say you might get away with one layer generous layer of laquer but it depends how smooth you managed to get your previous coats of paint. And the laquer might 'run' too leaving hard blobs behind!
good luck,
If I was using hammerite I would:
1. Prep the cover as above with 600grit wet and dry.
2. Degrease it thoroughly
3 Brush a coat of hammerite on and leave it to FULLY harden.
4. Flat it back with 800grit wet and dry till smoooooth.
5. Keep going with layers and flatting till you can flat back and still have a solid layer of paint left.
6. Final flatting should be done with something like 1200-1500 grit wet and dry.
7. Cut it back with G3 cutting paste/or similar.
8. Polish it up with t-cut/similar stuff. leave for a week in warm conditions/indoors.
9. Wax it.
Wet and dry is always used wet.
Edited by Retro_10s, 27 November 2006 - 06:21 PM.
