engine oil pressure switch location
Posted 29 November 2006 - 08:39 PM
db_1_b.jpg 17.85K 20 downloads
it has the advantave of maybe have oil temp fitment to. what do you think good or bad idea?
Posted 29 November 2006 - 08:59 PM
If so, will you have room between the filter and exhaust?? Ane even if you have, will the temperature of the filter increase due to the proximity to the manifold??
Also, how much are these units?
I made an adapter on the lathe out of brass and fitted to the oil gallery plug in the head (gearchange side) on the 98 R1, not sure if your model year has this as some are cast in without the plug. I know a lot of people have had problems with them breaking but i think it is because they have drilled the hole too big. I have not had any problems at all in 3 years. Mine has a small hole drilled (~2mm). Remember you are only measuring pressure not flow rate so you only need a small hole!!
Dale
PS You can see pics of mine in my thread
Edited by R1minimagic, 29 November 2006 - 09:02 PM.
Posted 29 November 2006 - 10:17 PM
gonna have a look through your thread now. cant remember seeing the pictures!
Posted 29 November 2006 - 10:41 PM
no woories i found it on d.d's thread!
Edited by dean_chad, 29 November 2006 - 10:46 PM.
Posted 29 November 2006 - 10:48 PM
I thought it might be on Pete's when he blew his engine up!
Posted 29 November 2006 - 10:50 PM
Posted 29 November 2006 - 10:55 PM
Posted 29 November 2006 - 10:57 PM
Picture_047.jpg 224.84K 7 downloads Picture_050.jpg 178.03K 26 downloads
I seem to have no drillling at the gear side of the head so the small fitting on the oposite side of the oil channel looks to be where mine is. looks very small.... is it the same as in the later models like pete and ades?
think im going to measure the filter housing tomorrow and go down that route tomorrow, might fot a oil temp sensor too.
Edited by dean_chad, 29 November 2006 - 11:14 PM.
Posted 29 November 2006 - 11:05 PM
Posted 29 November 2006 - 11:17 PM
Posted 29 November 2006 - 11:23 PM
Edited by dean_chad, 29 November 2006 - 11:24 PM.
Posted 29 November 2006 - 11:29 PM
Posted 29 November 2006 - 11:32 PM
