how do i fit this onto the mini?
miniman5
, Aug 31 2004 09:23 PM
9 replies to this topic
Posted 31 August 2004 - 09:23 PM
Hello ive got a centre exit back box and wonderd how to mount the bit nearest the back of the car the ovious thing to do is cut drill the subframe im unsure about this because of strenth any one got any ideas of what i could do?? heres teh bracket (picy is pats as i took it with my web cam! sorry!)
Posted 31 August 2004 - 09:56 PM
yeah your right you need to drill a hole in your subframe for teh mounting, don't forget the rubber mount :tongue:
Posted 31 August 2004 - 11:17 PM
If your subframe is original or has been replaced with genuine it should have holes already there. Thats why this back box comes with this sort of mount. Do mount it with rubber 'cotton reel' type mounts (or something similar) because you will get loads of nasty drumming noise off the silensor.
Posted 31 August 2004 - 11:34 PM
I've got a centre exit rc40, we had to drill the subframe and the RC40 fitting kit includes 2 rubber mount things. Cant hear any vibrations from the box.
Posted 01 September 2004 - 07:47 AM
ohh i didnt get any rubbers. this is a new subframe it doesnt have the holes. how could i mount it with them rubbers?
Posted 01 September 2004 - 10:49 AM
You line it up. Drill the holes. The rubber mounts are simply two fat rubber washers that fit in between your exhaust bracket and the subframe. You will need two nuts and bolts to fix each side of the bracket to the subframe. The rubber mounts absorb vibration and stop the bracket from snapping and git rid of horrible noises.
Posted 01 September 2004 - 10:51 AM
To avoid confusion
That's two nut and bolts in total, not per side.
Posted 01 September 2004 - 02:12 PM
You could use tape instead. Do it hardcore-style.
Posted 01 September 2004 - 04:25 PM
when fitting mine, i had to goto work before we cud drill the subframe, so we tied it round with metal rope. all was fine until i left it behind when i hit a slight bump in road.
Mount it proper.
Mount it proper.
Posted 02 September 2004 - 08:11 AM
HAHA! oh dear ! lol they sent us a 3" an dwe wanted a 2" so its gone back! so ile have anther one in a few weeks
