Are people using Sump baffles?
13 replies to this topic
#1 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 11 December 2006 - 05:37 PM
Hello folks,
Everyone I have spoke to with a bike engine kit car has told me to put a baffle the sump. I've looked into it and for £65 it seems a good idea. These folks ( https://www.fluke-mo...products_id=169 ) sell one that simply bolts in under the oil pick up pipe.
Has anyone else put one in, or killed an engine at the track by not having one?
Edited by Alburglar, 11 December 2006 - 05:37 PM.
#2 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 11 December 2006 - 09:36 PM
After speaking to Lynx AE last friday, I was told that baffled sumps ar a waste of time. Jon races his own designed LR1 so he should know as he takes reliability very seriously with his car. After all the LR1 will corner and stop alot better than any Mini.
Edited by Oldskoolbaby, 11 December 2006 - 09:40 PM.
#3 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 14 December 2006 - 02:00 AM
Well I haven't heard of of z-cars blow ups, but the two guys seperately who have raced bike engine cars and side cars have told me it's a must.
Anyone else had any experience?
#4 gizmo
gizmo
  • 132 posts
Posted 14 December 2006 - 03:26 AM
yes we do here in states.any time you take bike engine and stand it up permanent you should baffel its sump. in a bike it leans and cintrifigle(?) force feepsoil in sump/pickup. in car it sloshes from side to side. any how if you burn bearings just once itle cost alot more than 20/30$ to fix
#5 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 14 December 2006 - 08:51 AM
Al I read an interesting article about this topic somewhere on the net (cant find the link just yet) the dry sump was the safest method but expensive. Sump baffles have to be of good quality as the cheaper ones can crack due to high freqency vibes.
i have seen a busa engine with a hole in the crank case result of home made sump baffle. One the site i was reading most people just put a little bit more oil in and had no probs. modern bike engines are not as prone to oil surge like when riding on the back wheel for miles.
#6 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 14 December 2006 - 03:18 PM
I might buy one and decide if I'm gonna fit it, if it looks beefy enough.
#7 supermotolee
supermotolee
  • 1,120 posts
Posted 15 December 2006 - 06:34 PM
i got one off a guy on ebay who races bike engined cars i'm going to be inspecting the gearbox and clutch on my 4xv motor so might as well put one in it seems sturdy and as long as it doesnt break it can only help
#8 Dick Dastardly
Dick Dastardly
  • 261 posts
Posted 14 January 2007 - 10:19 PM
I've baffled mine.
Peace of mind and all that.
#9 adyzr1
adyzr1
  • 257 posts
Posted 14 January 2007 - 11:05 PM
chris told me a while ago its not needed in a z cars r1
most kit cars have them as the engine is bolted in front to rear and not transverse, i.e alot of oil surge under hard braking
(see pic)
  • Attached File  r1.jpg   32.67K   14 downloads
Edited by adyzr1, 14 January 2007 - 11:13 PM.
#10 fishywick
fishywick
    Just On Tickover
  • 6 posts
  • Local Club: None
Posted 15 January 2007 - 11:13 AM
I have a little experience of bike engined kit cars, but of course their engines are almost all mounted
front to back, the opposite to the bike.
In these circumstances it is generally accepted that the R1
should have a baffle, no need for dry sump even on a track.
A Busa is generally Ok on the road with a baffle but for track
a dry sump is a necessity.
Don't suppose that helps because you are all transversely mounted but thought I would mention it anyway!
#11 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 15 January 2007 - 06:54 PM
I think I'll put one in anyway - For £60 it's peace of mind for little money
#12 z cars chris
z cars chris
  • 469 posts
Posted 15 January 2007 - 08:07 PM
we have never baffled a sump unless we have had to cut the bottom off it for ground clearance and therefore lost some of the capacity and the "sump" effect of the lowest part of the sump
we always run with the oil level at the top of the sight glass when the engine is ticking over on level ground this means that the oil is fully around all the internal oil ways and running back into the sump from the head etc
you can get about half to three quarters of a litre of oil out of the sump and into these parts of the engine therefore by filling the sump level to the top of the sight glass when ticking over you are ensuring an adequate supply of oil at all times
if you look at the level when filled to the std height in the sight glass it actually empties it out as its pumped around all the galleries
chris
#13 PushingTin
PushingTin
  • 75 posts
Posted 08 September 2013 - 02:21 AM
I had an engine failure on Thursday, I've yet to take out the engine but I suspect oil issues with high G... Time to play with a new motor and tweak!!!!
PT
#14 Birdman
Birdman
  • 400 posts
Posted 08 September 2013 - 01:53 PM
I have the Hayabusa in my Monte Carlo.  Rigid mounted sideways of course.  I blew my 1st engine from starving it of oil in the corners.  1st thing I did was add a low pressure idiot light, a really big 2" LED light that comes on at 25 psi.  I then modified my stock pan.  Cut the bottom off and welded a bigger sump on it.  The sloping sides act as baffles, but I also added a baffle at the front to stop losing oil pressure durning hard braking.
  • Attached File  4.jpg   27.68K   16 downloads
Edited by Birdman, 08 September 2013 - 02:30 PM.
