I've watched the builder video, but I wondered: Once the rear subframe is fitted, if one had to replace or pull the engine for any reason, how would that be done?
There doesn't appear to be enough room through the rear window for it, would you drop it from below?
Thanks in advance,
Chris
Engine replacement
SAILINON
, Dec 18 2006 03:39 PM
7 replies to this topic
Posted 18 December 2006 - 03:39 PM
Posted 18 December 2006 - 03:48 PM
As far as I know it can only go forward, so remove seats and bulkhead and take it out of the door
David
David
Posted 18 December 2006 - 07:14 PM
As David says seats out, bulkhead,pipes,chain and wireing then six bolts holding the engine and just pull it forward on to the floor.
simple
simple
Posted 18 December 2006 - 08:20 PM
I thought on the later kits the engine could come out from underneath? Am i wrong??
Posted 18 December 2006 - 08:57 PM
Think David's right.
Unless you own a pickup and then you just lift it straight up
Edited by pete, 18 December 2006 - 09:37 PM.
Posted 18 December 2006 - 09:07 PM
Posted 25 December 2006 - 12:30 PM
you aree right in thinking it comes out through the front,this takes a couple of hours to remove the seats and front of bulkhead then remove water pipes throttle cable etc unbolt all mounting bolts and pull out forwards into passenger side once in there it can be lifted out over door bar easily or if you want unbolt door bar to give even more roomTo wide to come out the bottom Dale
rear_frame_engine_2.JPG 105.89K 39 downloads
the v tec actually drops out from underneath just undo all four engine mountings remove exhaust manifold all water pipes and throttle cable fuel lines etc
then lift whole car up almost like the reverse of the fitting process but leaving the roll cageetc still in the car you are left with engine and box complete laid on the floor and you can then do whast you want with it
chris
Posted 28 December 2006 - 04:14 PM
Thanks all, it had my feeble mind stumped!
Take care,
Chris
Take care,
Chris
