subframe paint
Posted 30 December 2006 - 02:04 PM
i have had some of my suspension parts powder coated, and was going to go for this on the subframes, but have been recommended not to do this as it will flake off, and water can get underneth it.
so what i would like to know is what can i use on the subframes that will be tough, but also have a neat finish AND is available in gun metal grey.
i have been experimenting with hammerite and managed to mix some black and silver to get the shade i wont, but i dont want to brush it on as it leaves brush marks (fussy i know but i want a show finish), is it posible to spray hammerite? what could i use as thinners, i tried white spirit but is seams to seperate the silver and black?
please help with any ideas
cheers
andy
Posted 30 December 2006 - 02:09 PM
Posted 30 December 2006 - 02:20 PM
you can get smooth hammerite in rattle cans
But it's over priced in a spray can and you don't get much.... I'f I'd were you mate... I'd seriously consider getting some thinners and roller it on for a good smooth levelled finish.....
Edited by Retro_10s, 30 December 2006 - 02:20 PM.
Posted 30 December 2006 - 03:38 PM
does that mean in need to use that rustoluem stuff?
Posted 30 December 2006 - 04:28 PM
as in just normal thinners used in car paint,
No i mean hammerite! with Hammerite thinners.... you'd have plenty in a small tin for a few good protective coats on there....
Posted 30 December 2006 - 04:37 PM
it will have to be sprayed i think as the roller just wont get into all the tight places.
cheers for the info
Posted 30 December 2006 - 04:47 PM
oh right i will have to have a look for that.
cheers for the info
you aint used a roller before
If you get the spray cans... get 2-3 cans, you hardly get any in the can, it's all air, also the nozzles will clog the second you stop spraying, they're useless, and the consistancy is nothing like the brushable form... you'll need quite a few coats for it to look half way decent..
'Dogmatix' has just brushed his subframes and they look great, he mixed yellow and red hammerite and brushed it on... if you use a soft pure bristle brush you wont get hairlines when set..
Edited by Retro_10s, 30 December 2006 - 04:48 PM.
Posted 30 December 2006 - 05:04 PM
yeah i got the idea of mixing the paints from dog, i manage to mix up a really nice colour as well. i might do a tester and see how it comes out with the brush. and i will get hold of some thinners and fire up the compressor as well.
do i need to use a primer with hammerite or can i just go onto the metal?
Posted 30 December 2006 - 05:16 PM
Posted 30 December 2006 - 09:00 PM
Posted 30 December 2006 - 11:57 PM
Posted 31 December 2006 - 10:27 AM
Hammerite can be sprayed if you use thinners. Hammerite make a special thinners but its very expensive. I just used normal cellulose thinners...
Posted 02 January 2007 - 07:32 PM
i think i will get the hammmerite thinners, i dont mind paying a bit extra if i know it garanteed to work!
just need to finish drilling and welding up the frames!
Posted 02 January 2007 - 07:59 PM
thanks for that info, i might get some more POR-15 as i know its good stuff, spray that on, then spray a top layer of hammerite to get the colour.
Yeah, i use the POR15 thinners when i spray with POR15, but i use celly thinners to clean the gun out. This is where most of the waste is... You only need about 5% thinners for POR15, but end up using half the can to clean your gun...!!
Posted 02 January 2007 - 11:23 PM
For me,
Brushed on Red Oxide
then brushed one Hammerite (2 coats)
