As in the title, what kind of brake lines did you use? Did you kept the origional lines, made stainles steel ones or used flexible lines all over?
To compare I would like to know the thickness, material and brand of the lines to if you guys would like to share that.....
I'm going to run my VTEC on vented 7,9's from minisport and I'm figuring out what to do with the brakelines......
Thanks!
René
Brake lines
Renessy
, Jan 02 2007 05:26 AM
2 replies to this topic
Posted 02 January 2007 - 05:26 AM
Posted 02 January 2007 - 08:14 AM
Coper/zink mix for me from the master cylinder to the suspension points then goodridge flexis.
Posted 02 January 2007 - 07:20 PM
Same as Koss for the solid pipe but some other make of braided hoses for the suspension points(not sure what make as the came from z-cars). Managed to obtain a good pipe flaring tool so was able to make any size and shape pipe I wanted.
Edited by pete, 02 January 2007 - 07:21 PM.
