suzuki carbs
mic
, Jan 07 2007 04:52 PM
10 replies to this topic
Posted 07 January 2007 - 04:52 PM
hi! not quite for Z cars but i thinkin about puttin bike carbs on a weber manifold...... ive seen it been done before but confused on something.... all the carbs i seen on ebay say 'for injection' but can they be used as normal with just a fuel line and throttle cable?!
cheers
mic
cheers
mic
Posted 07 January 2007 - 05:49 PM
erm i think its only carbs type that are used on car engines unless you are going to use the ecu and all the crank position sensors and various other sensors from the gsxr, which id be suprised if that would work. I dont think it would be a straight forward bolt on job with carbs either. Could be wrong though?
Edited by dean_chad, 07 January 2007 - 05:50 PM.
Posted 07 January 2007 - 06:25 PM
Posted 07 January 2007 - 06:29 PM
koss why use the 36mm carbs? What size cc engine are 36mm designed for? or is that not how it works?
Dean
Dean
Posted 07 January 2007 - 06:42 PM
yea had something like this in mind
ive seen em 36, 38 and 40mm but i dont know how that side of it works either
Posted 07 January 2007 - 07:02 PM
36 x 4 is 144mm thats a big carb if you look at it as a single carb. But if its going onto a 16v 1.4 k series i am sure they will be fine.koss why use the 36mm carbs? What size cc engine are 36mm designed for? or is that not how it works?
Dean
the ones in the link are off a 1100.
They will have to be dynojetted too.
Posted 07 January 2007 - 07:23 PM
dynojet?
Posted 07 January 2007 - 07:33 PM
Posted 07 January 2007 - 09:00 PM
what kind of performance would they be like compared to twin webers?
Posted 07 January 2007 - 09:55 PM
Someone on this forum is doing this with 2 yamaha carbs
http://www.theminifo...showtopic=39131
David
David
Posted 16 January 2007 - 11:47 PM
i have a mate called pete bogg, and thats not a made up name
his father dave and brother steve run a garage up here called bogg brothers they have been messing with bike carbs on all sorts of engines for the last ten years or so
they fit them to all sorts of cars from novas to rover V 8s and chevvys
the results are staggering basically a bike carb works very much like an SU EXCEPT its a lot better made and very resposive i know they have fitted them to a mini as i saw one up there last year sometime it sounded great although i dont know what power it was giving
they are on 01944 738234 tell them i put you onto them im sure they will help
the carbs in the picture look like ZX9R kawasaki ones to me and are perfect for modding
chris
chris
