engine conversion
9 replies to this topic
#1 MRclubman1100cc
MRclubman1100cc
  • 139 posts
Posted 11 January 2007 - 04:02 AM
Hey everyone at the moment i have modified 1098 in my clubman. But in a yr or 2 i am wanting to upgrade to a bigger engine, i am wanting fuel injection, what engine would i beable to put in with out to much modification..... i don't want a mini engine im looking for a non mini engine. what would i beable to drop in to it
plz help Todd
#2 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 11 January 2007 - 08:56 AM
You won't find anything other than an A series that will fit without modification. You can fuel inject an A series engine, but to fit anything else you're going to need a custom subframe and driveshafts, suspension etc.
#3 Jammy
Jammy
  • 25,397 posts
Posted 11 January 2007 - 09:38 AM
The ONLY thing I can thing of is to PM Scurvy Dog about the adpater plates he has, that allow you to fit a Xflow/Lotus twin cam engine onto mini gearbox. Anything else, as said above, will require you to get a welder out.
#4 MRclubman1100cc
MRclubman1100cc
  • 139 posts
Posted 11 January 2007 - 11:06 AM
well thanx fellas, when the time comes ill see what happens
#5 nag1_uk
nag1_uk
    Ring Runner 2005
  • 227 posts
Posted 11 January 2007 - 11:19 AM
Not too sure but you might get the 8v Vauxhall engine in with little mods. Allspeed do a frame.
Look at www.16vminiclub.com for details
#6 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 11 January 2007 - 11:55 AM
I don't think you need to do modifications for a MK1 Swift engine, and you can buy the frame from the 16vminishop.
#7 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 11 January 2007 - 05:05 PM
what about a mini engine ans 7 port head with injection?? that works a lot better than a standard 5 port head, when running injection on a mini engine there are lots of complications with the injector timing because of the shared inlet ports, i think even rover had to make a new ecu and even patented it because it was so advanced at the time.
for more information about injection have a look on the emerald website, he does give some information about the a-series lump on his sprite conversion.
A-Series Injection
Edited by fikus01, 11 January 2007 - 05:05 PM.
#8 MRclubman1100cc
MRclubman1100cc
  • 139 posts
Posted 16 January 2007 - 07:48 AM
yer ok then ill have a look at thoes web sites.. it just i don't have the funds for all the gear... how much would it cost to put the MK1 Swift engine in?
#9 ed4ran
ed4ran
  • 2,849 posts
Posted 16 January 2007 - 10:05 AM
Depends how much of the bits you make and do yourself, could be a few hundred up to a couple thousand.
#10 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 16 January 2007 - 02:56 PM
i recommend that you do a bit of reading on the 16mini club forum (http://www.16vminicl...orums/index.php). you will get a idea of the cost and work involved.
