Not true, the supercharger used in the kit from minispeed is an Opcon Autorotor twin scroll type, it is actually a compressor rather than a simple "blower" it is a LOT more efficient in terms of power needed to drive it for a certain boost pressure, and also temperature of hte charge at a certain boost pressure.There are supercharger kits designed for the A series specifically which have been around for a long time now. But the blower is a little less efficient than the BMW one,
The Bini Blower is perfectly adequate, and would be running at a low enough speed to outlast the engine several times over. The only issue with the Vmax kit is the same as with any other high power A series it just isnt strong enough. In fact, for the same output, the blown engine would probably last longer, as it can produce power at a lower RPM
