What's up Dawg's.......All good here.....Ok Ok..Here's the deal...Turboed Busa...I've got a late model vac. break booster and peddle assy. with master cly's on it off a Mini and was wondering if I should run this set up or someting different ???? If I run the vacuum set up do you think the motor will produce enough vac. to sustain adequate vac. in the booster...I might have to run an aux. vac. reserve to sustain adequate vac.....KAD 4 pot's in the frt. and stock Ford Zcars set up in the rear....What da ya think????? I'm open.....
thank You and Cheers Mates.........Willieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee...........
Brakes..Vac. or no Vac ??
Willie
, Jan 27 2007 12:04 PM
6 replies to this topic
Posted 27 January 2007 - 12:04 PM
Posted 27 January 2007 - 12:27 PM
willie, as long as you have a one way valve in the vacum line, you will be ok as you will be creating vacum when your braking as your foot will be on the brakes and not the throttle so not creating any boost.
Just us the standard valve as fitted in a standard mini vacum line.
Ps you will need more than KAD 4 pots to stop that thing of yours,trust me i have them on mine and they aint enough for serious use, See the other thread in the z-cars section.
Posted 27 January 2007 - 02:08 PM
Thanks Mark....I do have the check valve inline...Just was wondering if I was on the right track !!!! Bigger Brakes ???? Yep kind of thought so...Fricking High Speed Monster....I knew it I just knew it.....I'll check the tread on brakes.....Roger That......
Mucho Gras e es................Mu Cha Cha..............Willieeeeeeeeeeeeeeeeeeeeeee..........
Posted 27 January 2007 - 02:12 PM
" Alizee " YUM YUM YUM !!!!!!!! I Want ...I Want.......Such a Tasty young thing....Drippy...UMMMMMMM !!!!
Willieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.............
Posted 27 January 2007 - 09:07 PM
Hey Willie,
What size 4 pot KADs do you have? If you decide to get bigger ones, I might take yours off your hands if they will fit 10 inch wheels for my 8port mk1.
Cheers,
Aric
Cheers,
Aric
Posted 27 January 2007 - 09:42 PM
Cool Monte Busa.....I'll check um out and back wit ya on that....Yall all good up there ?????? We be good down here....Cold though .........
Willieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.......................................
Posted 27 January 2007 - 10:49 PM
Let me know....
Cold up here too, been doing a bit of work on my little monster though, see my newest post from today
Cheers,
Aric
Cheers,
Aric
