this is what a mini exhaust should sound like
#31
Posted 21 February 2007 - 09:42 PM
Hey anything other than a standard exhaust must sound better.. than the pea shooters fitted as standard.
#32
Posted 22 February 2007 - 03:15 PM
#33
Posted 22 February 2007 - 05:48 PM
My sounds beautiful ifa little rich i have seen full grown mechanics weep at its aswome roar hahah.
#34
Posted 22 February 2007 - 06:41 PM
...without the vibrations!
850, mine will revv alot better than all of yours hehehehe
#35
Posted 22 February 2007 - 06:46 PM
Wow, That Sounded.......Like A Normal 850Your all wrong!! This is what a Mini Should sound like ... and look like for that matter!
So What Rev Range Do You Get? (Before Power Curve Of Course)
#36
Posted 22 February 2007 - 06:48 PM
I think it will push to around 7000 but not adviseable, flywheel will disintergrate at 6500 rpm hehehe
#37
Posted 22 February 2007 - 06:51 PM
Christ That's A Lot For An 850! My 998 Pushes 7200rpm At Power Curve So Not Much Between The 850 and 998...I think it will push to around 7000 but not adviseable, flywheel will disintergrate at 6500 rpm hehehe
#38
Posted 22 February 2007 - 06:55 PM
The only difference is I will need a new engine and gearbox after it The 850's just the 'free revving engine' thats all really, nothing special, It can be bored to an 890 (I think) but theres no point really, not much in the way of power gains. Standards probably good for 30 bhp set up
O well!
#39
Posted 22 February 2007 - 07:13 PM
I'm not sure you're ready for this!
I quote (*ahem*):
" After December 1963 the crank shafts were conciderably strengthened, and are now safe upto 7000 - 7500 r.p.m though, occasional use fo 8000 r.p.m is quite common, especially if a vibration damper is used"
Tuning The Mini, 3rd edition by Clive Trickey
.... price 90p
Were'nt the vibo dampers fitted to early coop's ? ?
Tom
#40
Posted 22 February 2007 - 07:17 PM
#41
Posted 22 February 2007 - 07:19 PM
Interesting Find! So You Can Scream The Boll#ks Of Of It Now
lol I certainly wont! She sounds lovely when she's popping Putting a smalle bore Rc40 on, (side exit) The one with a rolled over tip Sweet ...
#42
Posted 23 February 2007 - 12:23 AM
#43
Posted 23 February 2007 - 09:08 AM
ill try and get a video up soon but iv had my pee shooter 998cc up to 8000rpm yes i know bad but didnt sound bad at all puurrred all the way up to 8000 and its been running fine ever since no even a nock or groan
You may have just Jinxed yourself!
#44
Posted 23 February 2007 - 10:16 AM
#45
Posted 23 February 2007 - 11:20 AM
Click below
ok you can only just here the exhaust, and the tappets are knocking there nuts off but you get the idea., the purpose of the video was for the carbs but there is a moment where you can here the exhaust. its a nice note on tick over i think...
there are other videos of her around some most prob show the exhaust better.
