Thanks Guys for the responses.
The dash lights come on. The alarm seems to arm and disarm and if the red light is flashing on the dash it won't bump start. Once I shut it off with the key fob then it bump starts.
red light flashing means the immobiliser is active, so it will not start..
after this light is out, i.e. key fob pressed if ti bump starts, then ecu is fine, your looking at a problem on the starting circuit.
Starter relay, wires to starter, or starter..
have you tried checking the starter to see you have 12v there when trying to crank it over ?
if you have 12 v..
bridge the 2 positive connections and see if the starter spins (make sure car is out of gear first)
if it spins starter is fine and it may be the solenoid, if this clicks (solenoid) when trying to start then it could be the connections in the solenoid.
