Hi, just a few questions:
throttle_bodies.JPG 358.75K
30 downloads
can anybody tell us what this is on the throttle body and what do we do with it?
throttlebodiestop.JPG 341.6K
28 downloads
Does anybody know about these outlets? have we got something missing as we dont know what fits in there
t_piece.JPG 347.5K
28 downloads
I presume these tubes are some sort of crankcase breather, i can see one goes to the left hand side of the air box, but where does the other one go to that comes off the T?
air_box.JPG 385.16K
19 downloads
Where does this pipe go to? there is another pipe attached to the crankcase which goes the the other outlet not arrowed.
We brought the car last year but have only just found time to start finishing it off, its the purple one that was on ebay if any of you remember it, thanks for the help
R1 engine
jacko299
, Feb 11 2007 01:16 PM
5 replies to this topic
Posted 11 February 2007 - 01:16 PM
Posted 11 February 2007 - 01:25 PM
I'm only guessing but
The first pic could be the fuel inlet and return lines
The second pic looks like either a leak-off or balancer pipe between the inlets
As i say though, i'm only guessing, have never seen an R1 engine in the flesh
Posted 11 February 2007 - 01:40 PM
The first pic is the water feed to the automatic choke. It raises the revs when cold.
The other is a breather pipe with a foam filter inside, this normally goes up into the airbox.
The water pipe will go to another T piece leading to the thermostat housing and to the top of the expansion tank.
Posted 11 February 2007 - 03:13 PM
The long pipe on the air box is the crank case breather. I have some pdf files of the entire cooling system but I don't know how to upload them.
Posted 11 February 2007 - 05:21 PM
Thanks for the replies, weve sorted out the breather pipe and the automatic choke inlet and outlets, the only thing were still not sure of is what could be the balancer in the second picture. Also if anyone has a good picture of where to mount the oil pressure switch on the engine could someone post it, were using the etb digi dash so it would have to be remotely mounted, we dont know where to fit it to the crank case. Thanks again, Jacko299
