i dont know if this will help but the compression for 2, and 3 has always been lower on all the A series engines iv ever done a compression test on and this includes 3 998s and 2 1275s. im asuming that the outer 2 cylinder have similar compression and so does the inner 2? if i was you id pick up and old head anyway, make sure its in alright condition, slim the faces, re gringd the valves in and stick it on with a new head gasket, make sure its torqued down correctly and you should gain a fair bit of compression. i woud also run a cleaning agent through the cooling system to clear any blockages(even if small).
Measure the wear on the bores, chances are you will get away with new rings and a hone, especially with that millage.
Reconditioning you box should be hard, it will last for ages if you correctly shim it out correctly
piston rings and engine in general
psycho mini driver
, Oct 07 2004 09:58 PM
15 replies to this topic
#16
Posted 09 October 2004 - 03:19 PM
