R1 oil pressure sender (etb)
9 replies to this topic
#1 adyzr1
adyzr1
  • 257 posts
Posted 15 March 2007 - 12:55 PM
Hi guys,
i'm remotely mounting my oil pressure sender (etb 1/8 npt) from the oil cooler bolt ......2 questions
1 .should i drill the oil cooler bolt to 1/8 npt or different? how do i do this aswell?
2. where do i get a braded hose with 1/8 npt male at one end and 1/8npt female at the other?
thanks ady :shifty:
Edited by adyzr1, 15 March 2007 - 12:55 PM.
#2 jacko299
jacko299
  • 49 posts
Posted 15 March 2007 - 08:44 PM
hey, weve just had to do this, drill the centre of the bolt and tap it out to 1/8 npt, we got our hose made up at pirtek, they'll make up any combination you want. Hope this helps
jacko299
#3 adyzr1
adyzr1
  • 257 posts
Posted 16 March 2007 - 03:10 AM
jacko299
thanks jacko,
do you know where i can get a 1/8 npt tap from? (i just have a staight set)
cheers
#4 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 16 March 2007 - 06:57 AM
Ady
1/8 ntp are quite rare. I managed to find an engineering works with one. You could use a 1/8 bspt instead and you can have your pipe made to suit. When you drill the hole you will only have 4mm wall depth. So insert the tap bit by bit and keep checking to see if the pipe fits nice and tight. You only get one chance.
#5 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 16 March 2007 - 08:55 AM
Why dont you get an NPT to whatever thread you engine has adapter? It is much safer and easier???? Demon Tweeks do sell them or any good motorsport shop to be honest?
#6 koss
koss
  • 1,399 posts
Posted 16 March 2007 - 10:37 AM
The r1 unlike the hayabusa does not have any threaded holes into oil gallery's. Apart from an oil check hole m4 thread in the cylinder head. So it is easier to drill and tap the bolt on the oil/water cooler.
Forgot to add. You will also need a 90 degree elbow with male/male ends. Otherwise you will melt the pipe on the exhaust.
£12.00 for the pipe, £2.00 for the elbow at my local hydrolic shop
Edited by koss, 16 March 2007 - 10:47 AM.
#7 adyzr1
adyzr1
  • 257 posts
Posted 16 March 2007 - 01:08 PM
Thanks Koss,
already got the 90 elbow and other bits,( noticed its close to the exhuast) :D
thanks for the advice on fitting , always nice to have a bit of warning on things like this :D
cheers ady
#8 bpirie1000
bpirie1000
  • 2,119 posts
  • Local Club: Amoc
Posted 22 November 2007 - 04:47 PM
any pics on this
would be gratefully appreciated.
Cheers folks...
#9 koss
koss
  • 1,399 posts
Posted 22 November 2007 - 05:08 PM
Pic of mine with a straight connector before fitting the 90 degree one.
#10 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 22 November 2007 - 10:14 PM
just finished mine oil pressure and temperature. I had to make the sandwich plate as I needed BSP threads but you can buy a 1/8 NPT M20 sandwich plate for less than 20 quid on ebay. Everything else I bought from thinkautomotive.co.uk
Edited by Alburglar, 22 November 2007 - 10:22 PM.
