Hi have fitted Gaz shocks to my 1993 Italian Job but the rear drivers side nut has come loose, I have tried to tighten it again but can't find any way to stop the top of the damper spinning. Any ideas?
Thanks in advance
Stevn
GAZ Shocks
Italianjob1275
, Oct 20 2004 03:00 PM
3 replies to this topic
Posted 20 October 2004 - 03:00 PM
Posted 20 October 2004 - 04:14 PM
I assume you're describing the "top" mount. Most shocks I've seen have two nuts that "jam" into each other to prevent them from backing off. These thread onto the top of the shock's rod. The top of the rod usually has a small wrench flat machined on it. Look carefully at the top of the shock rod and see if you' can't see small flats there and then look for a wrench that fits. Hold the rod with the small wrench and turn the nut(s) with the big wrench.
Posted 20 October 2004 - 11:03 PM
Yeah, the top of the threaded rod should be flat. Use a small spanner or an adjustable as DK says.
Posted 21 October 2004 - 07:22 PM
Thanks for your help I will try again at the weekend. The rattling is really getting on my nerves!!!
