Hey folks,
Tried the search, but it didnt work.
Has anyone fitted an engine steady to their MPI?
Is this the correct one:
Cheers!
MPI Top head steady
Commited
, Mar 29 2007 06:58 PM
6 replies to this topic
Posted 29 March 2007 - 06:58 PM
Posted 29 March 2007 - 07:42 PM
Looks to be the right one, and should fit in a similar maner to the SPi, Dev may be able to confirm this. There is another topic about these for the SPi and i said id take some pictures of mine installed. Havent yet but i will.
Posted 29 March 2007 - 09:49 PM
Would really appreciate if someone could get a pic of one on their SPI, double check that its the correct one?!!
I've just put it back on the road and the engines very rocky...
Posted 01 April 2007 - 09:50 PM
http://www.theminifo...showtopic=44425
I've had a look at an MPi today, some of the pipes are a little different but there is no reason why it shouldnt be very different from the SPi
Hope that helps
Best picture I could take of it
Hope that helps
Posted 01 April 2007 - 10:06 PM
Yeah that appears to be the right one to me.
as sprocket said though its a case of weaving throught the cables and pipes to fit.
mine is particulary crowded in there.
Posted 01 May 2007 - 03:00 PM
Yooo.
Just finished fitting my engine steady yesterday
Its available from http://www.avonbar.co.uk .
Basically fits every mini pretty nicely.
Only took about an hour an a bit to fit it, with help for the bulkhead bolts
I'd recommend it to be honest!
Although i think my gearbox needs a new steady to.
Posted 01 May 2007 - 05:51 PM
MMMM, Im not convinced by the two single shear bolts of the tie bar Looks good though and will function well
