best engine oil to use?
12 replies to this topic
#1 P91MER
P91MER
    Ring Runner 2005
  • 829 posts
Posted 26 October 2004 - 02:50 PM
there was a thread on here a long time back, with regards to what the best oil was to use in a mini engine??
can anybody remember what it was?
mine is a 1275 Inj
ta
Rich
Also i am after a set of NGK platinum tip spark plugs, as i have been told these will be better for my engine, than the cheap jack ones i have in there at the minute!
anybody know where to get them from?
#2 EVO6RSS
EVO6RSS
  • 27 posts
Posted 26 October 2004 - 03:10 PM
Mini Engines like in my experience and oil that isn't too thin. Something like a 15/50 of a 10/60. This is because the gaskets are C**p and much thinner it will just leak out. LOL!
I would also not buy synthetic, mini engines are supposed to be run on a mineral oil. I can't quite remember why though.. :P
Also ignore the advice of buying platinum plugs waste of money on a mini, esp one that is of relativly standard tune.. The only reason peeps buy platinum plugs is cause you can run a finer tip on them to get a stronger spark which is unlikly to be blown out buy cylinder pressures and they can stand higher combustion temps.
Cheers,
Rich.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 26 October 2004 - 04:03 PM
I don't know if there is a different set of wisdom for late model injected engines. The older A-series stuff runs very well on 20W-50. I use Castrol or Valvoline. As mentioned above, do not use synthetic. You need a little friction for the synchros in your gearbox to work well. Synthetics are a little too slippery.
#4 psycho mini driver
psycho mini driver
    1 Gold Star
  • 218 posts
Posted 26 October 2004 - 05:19 PM
im fed up of spending out on oil, it only get burnt or leaks, so i now buy wilkinsons 20w/50, 2.99 for 4 1/2 l of the stuff
#5 philster
philster
  • 1,255 posts
Posted 26 October 2004 - 05:24 PM
i always use duckhams 20/50 mineral oil, at only £8 a gallon it aint bad either. If the engine has done less than 60,000 you'll get away with 10/40. Don't use fully synthetic under any circumstances, its not the engine that doesn't like it more the gearbox.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 26 October 2004 - 06:04 PM
I use Halfords 10/40... never had a problem.... cleans off the drive without staining.. lol :cheese:
#7 Sam
Sam
    Wish i was in T.O.W.I.E
  • 2,323 posts
Posted 26 October 2004 - 06:17 PM
Yeah, same as mate.
Well infact, we mostly use cheapo Asda stuff now, just because it is easier then carrying two containers of oil through town!
#8 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 26 October 2004 - 09:57 PM
cheapo 20W50 stuff from asda lol, its 2.50 for 4.5L ill use some better stuff when i have my new engine in it. till then i dont really care as long as it works :P
#9 Purple Tom
Purple Tom
  • 4,921 posts
Posted 26 October 2004 - 11:20 PM
Halfords 15w40 - not too expensive and seems to do the job well enough.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 27 October 2004 - 08:22 AM
For those running in a new engine, make sure you use a pure mineral oil, with no additives, for the first couple hundred miles or so, will allow everything to bed in.
I use Penrite, but costs a pretty penny, think I paid 20 quid for 5 ltrs at a show.
#11 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 27 October 2004 - 03:46 PM
i used 10.40 and my car leaked in loads of places, using 15/40 castrol GTX oil because my dad gets it in 100's of gallons cheap.
#12 miniman5
miniman5
    1 Gold star
  • 3,135 posts
Posted 27 October 2004 - 09:33 PM
20/50 wil lge tu started mate! make sure your rocker gasket is on perfectly other wise itle come out the back or where ever it aint sitting right.
#13 hammoj28
hammoj28
  • 226 posts
  • Local Club: Scottish Minis
Posted 27 October 2004 - 10:21 PM
15/40 is what I use. And my Dad advised me to get Duckhams!! Meant to be the best.
