Hi,
I,ve seen somewhere someone using a cross brace to fasten seat belt harnesses to.Can any one give me a clue where to get one,I dont want to mount on rear pillar i don,t think there strong enough.
Thanks Nick Z-Cars gsxr1000 mini
harness mounting
nik1966
, Apr 08 2007 08:03 PM
3 replies to this topic
Posted 08 April 2007 - 08:03 PM
Posted 08 April 2007 - 08:43 PM
You could buy a piece of cds tubing, make some substantial brackets and secure it to the rear hoop.
On a heavy frontal with two people in it may bend without some middle support tho.
Posted 08 April 2007 - 08:46 PM
I think you will have to use original kit frame,like the engine mounting frame cross bar,or add another bar to the rear facing cage.the proper mini harness bar will never fit.
regards rob
regards rob
Posted 08 April 2007 - 08:54 PM
Hi,
If you search my thread on my old build you will see a harness bar made from 38-40mm cds roll cage tube. it was mounted across the main hoop and secured by clamps.
hope that helps
Ps im doing the same mod again to the new car so i may improve the idea a little, i will keep you posted
cheers
