need help
griff2
, Apr 11 2007 06:04 PM
10 replies to this topic
Posted 11 April 2007 - 06:04 PM
hi
i have replaced my (94) spi engine with another from a (92) spi engine i had been to see the engine running before i brought it so i know it worked and did not smoke but i have now put it in me car and it will turn over but not start i have checked the spark plugs, coil, dizzy leads, dizzy cap and arm but they are all working i also found that there was no power getting to the coil and anyone help i have try-ed every thing i can thing off
cheers
Griff
cheers
Griff
Posted 11 April 2007 - 06:29 PM
Do you have an immobiliser?
Is the ecu grounded properly?
Did you swap the ecus over?
Posted 11 April 2007 - 06:56 PM
the car does not have a immobiliser and i took every thing for the engine including the whole of the wiring loom front of the car as well, the only thing i did not take was the accelerator pedal switch witch i dont have on a 94 spi and i thing that it is grounded properly as most over things are working
cheers Griff
Posted 11 April 2007 - 08:47 PM
The ecu and engine loom from the 92 are incompatable fith the 94 body loom, the ecu in your 94 is a MEMS 1.9 with one connector and the 92 is MEMS 1.6 and has two connectors.
I wouldnt use the ecu from the 92.
Id be putting all the 94 stuff back in, ECU and loom, you should then not have a problem.
You can if you have the patience, rewire the connectors on the 92 loom to fit a 94 car, but why when you have a 94 loom?
This topic is a little confusing, to clarify. You have fitted a 92 engine, loom and ECU into a 94 car???
Edited by Mini Sprocket, 11 April 2007 - 08:47 PM.
Posted 11 April 2007 - 09:18 PM
the engine 94 engine blow up and i have had to change all the wiring apart from the rear of the car
Posted 11 April 2007 - 09:35 PM
You have changed the body loom , engine loom, engine ECU and engine to that you got from the 92 car, except the rear loom from the bulkhead to the rear of the car??
if you have not got the throttle pedal switch, id start there and fit one as its needed if you use the 92 ECU
Dont understand why you had to change the entire loom though, unless it was on fire?
Edited by Mini Sprocket, 11 April 2007 - 09:36 PM.
Posted 11 April 2007 - 10:13 PM
had to change all the looms as there were not service able to many cowboy had been playing with it.
putting a throttle pedal switch in tomorrow
Posted 12 April 2007 - 05:00 PM
i have now fitted the throttle pedal switch but still no joy i have also checked the fuse's all 8 of them and all ok the engine's earth is also ok any idea what else it can be ? need help only two weeks till riviera run and still need to get the engine going MOT and TAX
Posted 12 April 2007 - 09:25 PM
is the crank sensor a good un, is it plugged in and is the tip of it free of C**p. If the sensor is goosed it will never start.
Posted 13 April 2007 - 09:23 PM
have checked the crank sensor with a meter and it is fine, i have taken the wiring loom of to check it as i have checken all relays and fuses dont know what else to do
Posted 15 April 2007 - 05:22 PM
problem solved it was a broken earth conection and 2 broken wirer's within the engine wiring loom it self
cheers for all the help guy's n girl's
