De-seaming
#16
Posted 03 November 2004 - 12:03 AM
That would be quite funny, do the panels get REALLY hot all over, and start to crumple and bend!
never seen it been done before..
Rich
#17
Posted 03 November 2004 - 01:03 AM
#18
Posted 03 November 2004 - 02:09 AM
#19
Posted 03 November 2004 - 09:10 AM
As the car will end up having a Z-cars conversion it will have a fairly secure rollcage fitted so strength shouldn't be a worry...(famous last words??) :erm:
I'll be roping my dad in to help with the welding ( he doesn't know it yet :grin: ) He's been welding for best part of 25 years so will hopefully be handy.
Can anyone recommend what filler to use to smooth over the work? I chatted to a guy at Castle Coombe a few weeks back who said "only use a lead based one" as anything else will crack. But have no idea what types are lead based.
Thanks again Ade :cool:
#20
Posted 03 November 2004 - 03:07 PM
Al
#21
Posted 03 November 2004 - 04:24 PM
I know the stuff you mean and have used it before but I've only ever seen it in small tubes (like a tube of glue size) That could get a bit expensive buying about 800 tubes of the stuff :saywhat:
It is very good stuff though you can cut threads into it when it's dry and all sorts!!
Ade :cool:
#22
Posted 03 November 2004 - 10:47 PM
Not only does de-seaming a Mini make it look good, but it also makes it noticably faster. The body seams add roughly a square foot to the cross sectional area of the car, and removing them drastically reduces the drag co-efficient of the shell.
#23
Posted 03 November 2004 - 10:48 PM
Siggy
#24
Posted 03 November 2004 - 11:59 PM
Yes, no-gas welders are *******. No better than a filthy arc welder! Also worht nothing that it's not a good idea to use oxy-acetalene on a car body either.
oxy-cetalene on a car body
We used to use oxy-acetaline when we did grasstracking due to the fact that it is a far superior weld to mig. Yes it can warp panels (especially if you're not very good) but if used carefully it won't. We also made our own fuel tanks which had to be gas welded because mig was not considered a good enough weld.
As for no-gas mig welders being ******* thats probably down to the fact that you've used a mig and then tried a gasless one and couldn't weld with it. The bottom line is they are cheaper to run and as good as any hobby mig (when you've had some practice), a roll of wire is about £2 dearer than for mig but you don't have to buy gas. Also you don't get '*woman of ill repute*' like you do with an arc welder this is a myth, there is a very small amount of flux within the wire so that you can weld smoothly but not enough to cause deposits.
#25
Posted 04 November 2004 - 01:45 PM
Ok Sorry to be a bit dim here but lead loading????? What is it, how's it done, what's the usual cost etc etc.If it is done properly (not quickly and definitely not cheaply) then there is no strength problem. I know of deseamed cars that have flown through engineers inspections. The best ones don't use filler to cover the join, get it lead loaded mate. Costs a lot, takes a lot of time and a lot of skill but it will last forever.
I guess it actually uses lead (otherwise it would be an odd name) ,won't it be a tad on the heavy side? I'm asking because I going to be doing some fairly extensive weight reduction. Currently planning Carbon fibre front end, doors, boot lid and dashboard. So don't then want to add a whole bunch of weight by covering the car in lead.
Ade
#26
Posted 05 November 2004 - 01:42 AM
#27
Posted 05 November 2004 - 07:40 AM
only if it is done corectly !Lead loading fills up dents etc. in the body with lead, rather than filler. It's better because it doesn't crack.
#28
Posted 05 November 2004 - 02:05 PM
And if you're that worried about weight, leave the seams on. The reinforcing plates and yards of welding wire that you use will probably be heavier than the standard seams and covers, but you will gain the aerodynamic improvement so the two effects may cancel each other out!
#29
Posted 06 November 2004 - 11:05 AM
It does give a slight performance ioncrease especially at top end due to less drag as mentioned b4. If you look at the contours of the car a at the rear corner you shal see a lip which takes alot of filler and time to get it right, iv seen a couple of shells that have just missed this and looks rubbish.
if its purley for performance then leaving them on will aid acceleration, taking them off will aid top end, but you will noly be trying to squeese that exctra 0.1 second to 60 out of it
if its for loooks, then its not too bad, takes away some of the origionality, iv had a loilttle problem withn the paint reactinmg with the filler but nothing too bad as its mainly down to the rubbish paint job on the car!
#30
Posted 27 December 2004 - 04:14 PM
I'm in the process of making a classic race Mini into a street car (cough, cough). My mini was de-seamed in the process. It was stripped to a shell and the seam was ground off and MIG welded 6" at a time. The welding process is typical of any sheetmetal welding - don't heat up too large of an section at a time. TIG leaves a nicer looking weld, but the reality is that you're going to grind and fill anyway and MIG will get the job done well.
We sealed the weld with spray, then fiberglassed to create the finished product. That finished project is now 10+ years old and there are no problems. Keep in mind that this is also a race mini, and has seen it's fair share of abuse.
Anyways, pictures are at http://www.poweredby...com/minicooper/
The car has some cheesie window nets int he photos - you can ignore those. I started the conversion to a street car a few weeks ago. Progress is going nicely.
-Rich
(USA resident alien. Moved from the UK 27 years ago)
