on my mini i have 4 spots and they really oull on the altonator and drain the battary!!
the mini will also have a nice sound system in it soon which will also pull alot of power!!
anyone know where i can get a larger capastiy altonator for the mini or if i can take one off a different car that has more power??
altonator
MINIon
, Nov 07 2004 04:31 PM
5 replies to this topic
Posted 07 November 2004 - 04:31 PM
Posted 08 November 2004 - 01:58 PM
Posted 08 November 2004 - 07:06 PM
Can't say whether you can easily fit a higher output alternator unless you tell us which one is fitted currently. What year and model is your car? You don't drive around with all your lights on all the time do you?
Posted 08 November 2004 - 08:11 PM
not driving around with them on all tokme but i live out in country side so have main beam on alot and you can see the light getting dimmer as it drains the barrary!! the system i got planned going to drain bigtime on the barray even with power caps!!
Posted 08 November 2004 - 11:48 PM
I've know of people fitting alternator's from Rover 800's, and a mk3 transit battery just fits in the battery box. Make sure it's all got suitable wiring and fuses.
Battery is expensive so mayB try the scrappy and look for a good one, check with multimeter or battery charger/checker...
Dave
Dave
Posted 10 November 2004 - 09:01 PM
Wood and Picket do an unprated one it aint cheap but that depends on your buget here is a link
http://www.woodandpi...e=mini&dep_no=6
Im interested in the idea of using a rover 800 alt though do you have any more info on this dave
Matt
Matt
