Cat or not to cat?
Posted 04 May 2007 - 03:09 PM
Sorry if this has been asked before, I have just had the car MOT'd and failed and the main problem i've got is getting through the emissions. I have a 93' SPI cooper and it originally failed massively on co2 emissions. After getting the emmisions tested again today with the engine thoroughly warmed up (original mot she was pretty cold) she still failed. My question is, is it worth me buying a new catalyst or are there any other options I can look at?
Budgie[/color]
Posted 04 May 2007 - 03:55 PM
If the car was supplied with a cat then it MUST pass the cat test if there is a cat present or not... if it's failed twice then it would suggest that the cat is fubar'd therefore will need replacing...
If it were a carbed cooper, then you could have probably got away with leaning off the mixture, but with an SPI you have no means to do that...
Posted 04 May 2007 - 04:05 PM
Posted 04 May 2007 - 04:15 PM
Posted 04 May 2007 - 04:32 PM
alsorts u need to check before u replace the cat if its failing massively then its the fueling not the cat, what spec is the engine? check the vac pipes r clean and not split, check its got the right temp thermostat, check the temp sensor and check the lambda sensor im sure there more to check but cant remeber off the top of my head
1.3i, the vac pipes are brand new and so is the map sensor, thermostat is about 8 months old but haven't checked the lambda sensor, how easy is it to fit?
Posted 04 May 2007 - 05:04 PM
Incidently I have moved this to the Injection specific section
Posted 04 May 2007 - 05:07 PM
My sisters went through the MOT with a cat replacement pipe and that passed
Chances are that the MOT tester, tested it on the BET rather than the Cat test
Posted 04 May 2007 - 07:47 PM
Posted 04 May 2007 - 08:11 PM
Posted 04 May 2007 - 09:50 PM
If the Lambda sensor was changed not long ago and its still running rich then that was not the fault but rather a symptom.
Posted 04 May 2007 - 09:53 PM
You had the Map sensor replaced? The one inside the ECU?
Posted 06 May 2007 - 12:46 PM
Posted 20 May 2007 - 09:21 AM
I had similar problem recently. Solution appears to have been either curing blowing exhaust gasket or faulty Lambada both of which were sorted at the same time. Can you tell if exhaust manifold has a good seal ???
As long as you can't see fumes coming off it. (although if you have a driveshaft oil leak this could just be oil.)
Posted 20 May 2007 - 09:22 AM
the lambda sensor r expensive from minispare ect bwt £80 or sumthin think someone has a link for them at about £50 though, u have to take the exhaust manifold of ideally because its a nightmare to get the sensor out, needs loads of heat, so its inlet manifold removing seperating the downpipe u need a big extension bar for this and then removing the exhaust manifold so u can put enough heat through it get good leverage etc
I got a genuine one For £62 from a local bosch agent. (CAS in norwich)
Posted 21 May 2007 - 09:26 PM
