Dash pot problems...
10 replies to this topic
#1 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 20 November 2004 - 05:41 PM
Engine cuts out at low revs, and swiftune suggested that the dash pot was sticking and was something that they picked up whilst running my new engine in.
I removed it yesterday to give it a good clean through with new oil, and loads of bits of plastic came out. It's where the plastic cap is treaded and some bits had grated off it. Put it back on but was still cutting out.
reomoved it today and found a big chunk missing from end of the recessed guide. you can just about make it out in this pic.
#2 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 20 November 2004 - 05:42 PM
Where can I get a new dash pot from for reasonable money?
...and should there be a gasket in between the dash pot and the carb?
#3 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 20 November 2004 - 05:58 PM
hi al
what type of carb have you got fitted HS4 OR HIFF44, though i do believe that the pot sizes are all the same, so it will be a 1 1/2 or 1 3/4 carb, i have a couple of good dashpots from a 1 1/2 HS4 plus a 2nd hand HIF44 sitting in the shed.
there is no gasket between the carb and pot.
also what condition is the pipe from the breather to the carb?
:wales:
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 November 2004 - 09:16 PM
Are you replacing the Pot ( suction chamber ) or the piston, eitherway, you'll need to perform what is called the drop test when you bring the two together. This makes sure that the fit is not too loose or tight...
Taken from SU maintenance manual....
To check the piston on standard suction chambers, lightly oil the piston rod, assemble the piston to the suction chamber, and fit a large washer to one of the lugs. Do not fit the spring. Dip the damper in oil, then tighten in the suction chamber. Temporarily plug the two transfer holes in the piston. With the suction chamber inverted, check the time take for the suction chamber to fall the extent of it's travel. If the time taken is not 5 to 7 seconds check the components for wear, misalignment and cleanliness
#5 siggy
siggy
  • 1,110 posts
Posted 20 November 2004 - 10:28 PM
Thats a piston you need not a dash pot.
Unless the carb has had time spent reworking it get a complete carb. Fitting a piston from another carb can cause the piston to stick.
Siggy
#6 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 21 November 2004 - 11:00 AM
i've got a good HIF44 if thats any good to you, will be retesting it on a diffarant car today, so PM if you want it
:wales:
#7 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 21 November 2004 - 05:00 PM
hi al
:wales:
Sorry, school boy error!
It's an 1 3/4 HIF44.
How much do you want for the 2nd hand HIF44?
Breather pipe looks ok
#8 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 21 November 2004 - 05:04 PM
yeah it is the piston in the pot, not the actual pot.
But may be sorted if me and cowboy strike a deal.
#9 Sunshine
Sunshine
    Friend of TMF
  • 785 posts
Posted 06 December 2004 - 09:44 AM
I have posted out the carb today to you. sent recorded next day so you will have it soon....
oh yeah, been very well packaged to prevent damage.... i love bubble wrap :lol:
#10 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 06 December 2004 - 10:19 AM
Ta muchly
#11 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 06 December 2004 - 10:22 AM
isnt it great how a community of friends can help each other out?
