Exhaust Woes
Posted 15 May 2007 - 05:51 PM
Below is a pic of the gap(4mm) with the old ebay manifold
Has anyone got any ideas? I'm at my wits end with it now
Posted 15 May 2007 - 05:53 PM
Posted 15 May 2007 - 06:05 PM
are you buying spi manifolds ?
How do I say "I'm not stupid" without causing offence
Posted 15 May 2007 - 06:37 PM
Posted 15 May 2007 - 06:41 PM
The auto subframe moves the engine forward a bit... i think they use it on turbos to give extra clearance which would mean that the manifold is also a fraction further foreward than it should be.... was the auto manifold different and could you put a lamda sensor tap on to it?
Posted 15 May 2007 - 06:49 PM
as a 1275 block is taller
Posted 15 May 2007 - 07:36 PM
so are you keeping it auto????
are you leaving it a 998 engine ?
Surely the manifold is bolted to the engine along with the drivetrain. So if the engine mounts were in a different place it wouldn't change the relative postion of the exhaust manifold to the CV joint?
No I'm not keeping it auto. I swapped over the entire front subframe/engine assembly from a manual 1275 Spi
Posted 15 May 2007 - 08:44 PM
Posted 15 May 2007 - 09:05 PM
Posted 15 May 2007 - 10:57 PM
One thing i do notice, whether it has any bearing on this, is the joint boot used on the inner joint is he wrong one.
to be honest Maniflow are the only manifolds to use for this reason.
Some things to consider. The later 1275 subframes have the engine sitting 12mm forward of what would be the norm. The engine tie bar on both these later 1275 cars and all autos is 12mm longer. Later 1275 gear selector rods are 12mm longer.
So, say for instance, you fit the engine in its normal position but use an auto or late 1275 engine tie bar, the engine will be tilted forward, the maniflod outlets will be in the wrong orientation, if trying to compensate for this, there may be the issue you have.
Check that you are using all the SPi or late 1275 parts or all the original pre 90 non auto parts for fitting the engine correctly.
The SPi inlet manifold will fit with the engine in which ever location, the engine was only ever moved forward for the HIF carbs.
Oh and the other thing is Non injection exhaust manifolds foul the bottom coolant pipe of the injection inlet manifold.
Posted 16 May 2007 - 05:15 PM
Are you sure the manifold flanges are square and flush to the head,if they are then its down to the quality of the manifold and nothing else.
That was the first thing I checked. My first thought was a poor quality manifold, hence the reason I brought another one. This is the second manifold:
Clicky
I also considered this. I used the tie bars form the later injection car. But I came to the conclusion that even if the tie bar was longer, it still wouldn't affect the distance from the exhaust to the cv joint as they would remain in the same relative postion to each other. It would mearly tilt the exhaust at the Y section upwards towards the floor of the car.
Nope no fouling. It really getting on my moobies now
Posted 16 May 2007 - 05:18 PM
