i am getting really annoyed with my car, i spend every weekend working on it and it just goes more wrong. i used to get to school and going out on £10 a week, i am still doing the same mileage, but now its costing me £30ish. i worked out i am only getting 26mpg. i have checked all the vacume pipes, as this was a problem last year, but they are all ok. its not even performing as good as it used to, ie, its slower. and to top it off i have a knocking noise coming from somewhere, it burns oil, needs lower sus ball joints, new pads and have the mot next week. i never seem to be able to fix it. any ideas why the excessive fule consumption, i can just about live with the rest. (o, and its a 1.3 spi cooper)
psycho mini driver
, Nov 26 2004 10:42 PM
8 replies to this topic
Posted 26 November 2004 - 10:42 PM
Posted 27 November 2004 - 06:33 PM
hum, whats the spec of it now, im only getting on average 24mpg. it changed loads as soon as the roller rockers went on
Posted 27 November 2004 - 06:37 PM
For better or for worse??
as soon as i get mine back i will have a see at how much fuel it is using. mine is doing my head in at the mo, its costing me a shed load of money, and not even for the best!
Rich
Posted 27 November 2004 - 07:00 PM
its only a gess but it could be running rather rich does it smell fuel when u stand behind itand its running?
Posted 28 November 2004 - 10:04 AM
I know I bang on about this, but a very common cause of faults on Mini injection engines is the coolant sensor. Does the temperature gauge work? If the injection ecu doesn't get the signal that the coolant is up to temperature the cold start routine will just keep running all the time, it's kind of like running on full choke. So it will burn more fuel, but more importantly it could wash the oil off the bores on every stroke severely damaging the lubrication and leading to engine wear.
Or it could be the inlet manifold air temperature sensor. If it thinks the inlet charge is cold it will be bunging extra fuel in again.
Posted 28 November 2004 - 08:06 PM
the roller rockers made it alot worse! though on an injection mini its more likely to be sensors!
Posted 28 November 2004 - 08:17 PM
wow, thanx for that dan! i have just been out, and yes you were correct. the coolant temprature sensor woire had come off. pain too get back on, but is on now. hopefully it will be sorted now. thanks again, i never would have found that in a million years.
Posted 28 November 2004 - 08:48 PM
i recon with all this good advice dan is giving he should have another gold star!
Posted 28 November 2004 - 09:40 PM
i agree, i was thinkin that, as hopefully, it will save me hundreds over a year
