PS: i have bolted it all up again after takin the gaurd of is it ok to drive with out it on??
Where can i get one of these...
miniman5
, Nov 27 2004 07:02 PM
17 replies to this topic
Posted 27 November 2004 - 07:02 PM
Ok after the accsident the disc cover as i have been calling it is totaly wrecked.... where can i get one of these from? and what the proper name for it!?!?
Posted 27 November 2004 - 07:12 PM
Don't worry about driving around without the gaurd on, many people take them off completely!
What I would be worried about is that fluid/grease that's on the gaurd! Find out what it is where it came from and whether it got on the actual disc or not... That will cause you a lot more trouble than the lack of a gaurd!!!
Posted 27 November 2004 - 07:31 PM
thats freeing oil mate! lol trying to undo the screws!just undid the bolt instead
Posted 27 November 2004 - 07:46 PM
Oil? If any of that got onto the disc you'll need a new disc, and looking at the pic a pair of new discs probably wouldn't be a bad idea anyway :] Might as well change the pads while you're at it!
Posted 27 November 2004 - 09:03 PM
you dont need to change the disc if you get oil on it!...
just clean it off!
just clean it off!
Posted 27 November 2004 - 09:26 PM
Yeh, ditch the guards, aparently there to stop stones gettin in, but with the chippings they use round our way, they just trap beteen the guard and disk... Squeeeeeeeeeeeeeeeeelllll :nugget:
Right pain in the royals they are !
Posted 27 November 2004 - 09:51 PM
u can buy new ones from many of the mini shops, e.g. mini speed or mini sport.
Posted 27 November 2004 - 10:36 PM
if the oil gets on the pads it will contaminate them and they'll need changin so dont get it anywhere near th pads, if it gets on the disc just clean it off with brake cleaner
i think most people run without those shields.
DAN
DAN
Posted 27 November 2004 - 11:08 PM
hmmm, im worried about my wheels now.
cant you get them done up to a certian rating or sommit at a local garage, and what is the recommended rating?
Posted 27 November 2004 - 11:14 PM
hmm ok thanks u guys! i dont think i got any one the disc but i will check anyway! thanks your all great!
Posted 28 November 2004 - 07:18 AM
The sheilds are there to prevent water getting on the brakes, You can remove them, I always do, but be carefull in very heavy rain or through standing water as this may effect the braking.
Siggy
Siggy
Posted 28 November 2004 - 08:58 AM
Ditch em they just add weight, never run the rally Min with them on and that sees plenty of water on the brakes.
Posted 28 November 2004 - 09:56 AM
It also sees more brake use than most road cars though, so the discs and pads will be normally running at a higher temperature than the road car so the water boils off more readily. And a road car is more likely to see an emergency stop than a rally car, there's no one sitting next to the driver telling them what comes after the next bend.
I usually run the disc shields, but you can leave them off if you want. They do serve a purpose but as you can see lots of people ditch them. I think they are around twenty quid for the set, but you might be able to just buy the damaged parts. Most places sell them, and don't get ripped off for them by the scrappy or anyone if you get second hand ones 'because they've never been rare parts.
Posted 28 November 2004 - 10:42 AM
If you cant get hold of any of those shields ive got a set laying around you can have, thats if you really want to run them of course.
Posted 28 November 2004 - 05:22 PM
yea can i have them please pickup :grin:
