12G295 Head
5 replies to this topic
#1 Purple Tom
Purple Tom
  • 4,921 posts
Posted 02 December 2004 - 05:59 PM
Hi,
As you know I bought that 72' Clubman, and it came with a 12G295 cylinder head loose as part of the deal. It is in excellent condition, I can't find any cracks anywhere on the casting (have examined it thoroughly with a magnifying glass), and the inlet and exhaust ports are lovely and smooth. The valves are present, but the springs are not, neither are the colletts. It has 2 slightly bent exhaust manifold studs, which may straighten, but more likely will need replacing, which isn't a problem. It is obviously still leaded, so will need a conversion if you want to run it on unleaded. This will obviously entail the valves being reground, which I would probably do anyway. It has the transfer hose outlet in place, and the studs for the heater output studs in place too.
I'll put some pics up in a second, what I'd like to know is how much will it be worth, and is it worth selling it?
Cheers!
Tom
first pic
#2 Purple Tom
Purple Tom
  • 4,921 posts
second pic
#3 Purple Tom
Purple Tom
  • 4,921 posts
Posted 02 December 2004 - 06:00 PM
third pic
#4 mini90
mini90
  • 118 posts
Posted 02 December 2004 - 07:05 PM
295 is agood head for the small bore engine well worth selling if you're after recouping some dosh, These heads where fitted to the 998 Cooper, you should get a decent price
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 December 2004 - 07:25 PM
I've seen them go for 50 notes and more on ebay... if you have the rocker gear and valves, be worth building it up, easier to sell..
#6 Pavel
Pavel
  • 2,451 posts
Posted 02 December 2004 - 07:32 PM
Rebuild it and use it on your pickup or clubman!! It's a great head, and rare as heck, so you get those uniquness points too! :lol:
