The problem is solved by Rover by having differing injector durations for the same load (normally all the same) and changing the phasing and/or injection start pointt for the port in question.
But this only works for a certian output. At high rpm say 6000 rpm you end up with sooo little time (5 ms) that you need a huge injector (1000cc) to inject all the fuel required for one cylinder in one go! It simple doesnt work and you can control an injector that size to idle on a small engine....
Alex
megasquirt ECU
Woody
, Dec 02 2004 06:32 PM
17 replies to this topic
#16
Posted 09 December 2004 - 03:55 PM
#17
Posted 09 December 2004 - 05:31 PM
I believe that twin carbs with its straighter inlet tract helps to get a more even suply of fuel at each cylinder ( a friend with split 45dcoe webbers explaned this to me ) that is one of the reasons i was thinking of going for 2 throtle bodies (possably made from SUs) this would mean 2 injectors .
is the megasquirt sequential ?if so it might be possable to fit 4 injectors , each one pointing directly at the cylinder it is suplying ?
#18
Posted 09 December 2004 - 08:36 PM
a st8 inlet track will not solve anything... it will flow better and so be better power wise but it CANT stop charge robbing.
MS is not sequential.
Alex
Alex
