Click HERE to see if you can help out.
Has anybody had a balljoint failure?
Dom
, Dec 02 2004 09:04 PM
9 replies to this topic
Posted 02 December 2004 - 09:04 PM
Posted 02 December 2004 - 09:34 PM
Ouch !
but saying that, depends where they came from, and who fitted them ! nothing more constuctive could be added to the thread.
Posted 02 December 2004 - 09:43 PM
Jeez!!! Lucky guy, could have been alot worse.
Hope he can get compensation but it sounds a bit tricky.
Posted 02 December 2004 - 09:47 PM
wow thats horrific! So that was caused by defective rather than worn ball joints right? I had to re shim mine recently to reduce the play to correct levels, is that dangerous?
Posted 02 December 2004 - 10:36 PM
thats the idea of the shims, so you can take up the wear. but , obviously, if the pin or the inside of the big nut is very worn, then change them, as they are very cheap.
Posted 02 December 2004 - 10:41 PM
wow, reminds me of what mine looked like, but mine was burnt too
Posted 02 December 2004 - 11:30 PM
Never had one fail on a mini (except at MOT time :grin: ) but did have one pull out on my Rover 800 - pretty scary experience but fortunately I was only going slowly at the time.
Posted 06 December 2004 - 11:15 PM
never had a ball joint go.... but ive had the bolt that holds the bottom arm in place snap before, letting the bottom arm go completely, which id imagine is similar
it happened to me going round a roundabout, on the outside wheel, and it was scary as f**k, just had no control, no drive, nothing.
not the kinda thing you should look forward to....
Posted 07 December 2004 - 11:35 AM
i cant ge tit to load btu where going to get ours checked out after the accsident dont want any more!
Posted 07 December 2004 - 12:16 PM
I was put off fitting some of the cheaper ones, (£7.50 ish) to TC's and Jem's cars by someone who knows about these things and just had them reshimmed by a reputable garage (JONSPEED in Nuneaton). The better quality ones are twice the price but..... It was also suggested to me to use carburundum paste on the ball and socket to smooth out any rough spots, then clean out and grease before fitting.
