Constant 90mph on motorways?
Posted 06 December 2004 - 02:37 PM
Is it common for everyone with standard Mini Coopers ('97, P reg) with no engine mods (and only an RC40 exhaust and K&N air filter) to average 90mph on the motorways?
I'm generally sitting at 4,000 revs at 90mph, and about 4,300 at the ton.
Can the engine cope with this sort of constant revs and speed etc? Does this cause undue oil heating etc that might lead to longer term damage?
Can the rest of the car cope with this speed, namely, the breaks and suspension, if one has to break suddenly etc?
Cheers,
Posted 06 December 2004 - 04:14 PM
No, because that would be illegal!
Twinpoint Mini's were designed to do motorway miles mainly, that's why they have the ridiculous diff.
The published maximum speed for the twinpoint is 90mph and you should be seeing about 4300rpm at this speed, with 70mph being about 3700rpm. Your speedo is probably a little out (not uncommon) as you can't change the relationship between engine speed and road speed in any one gear without swapping the gearbox or FD (or wheels, so these figures will be slightly different for a sportspack). The new air filter wil have quite an effect on the car as the injection engine automatically re-fuels itself to cope with the extra airflow. Essentially it is kind of like fitting a stage 1 kit to a carb'd mini.
You could fit an oil cooler if you like as long as it is a thermostatic setup. The twin point injection computer monitors the oil temperature as one of its parameters so it would log any faults, ask the dealer at service time if there's anything recorded in the fault log. If you fit a cooler which is not thermostatic the engine sometimes won't run at maximum performance as the computer won't let it 'till the oil has warmed up properly.
A Series engines love revs (although the small bore is better than the big block), have you been to any Mini racing? That's a lot more tough on an engine!
Posted 06 December 2004 - 06:08 PM
mines at 5/6k rpm at 90-100mph
Posted 06 December 2004 - 11:20 PM
in am mpi i dont see 90 being much of a problem at all
EDIT: im also fairly sure that MPI's had a rather stupid 2.75 diff, which is just silly!
2.9 is tall enough, but 2.75 just seems mad
anyway.... im pretty sure all mpi's were 2.75.... correct me if im wrong
Posted 07 December 2004 - 01:16 AM
Posted 07 December 2004 - 01:48 AM
Posted 07 December 2004 - 08:53 AM
Its a 988, hs4 1.5",piperX cone filter,rc40 exhaust s/s single box with straight thru, lucas sports coil + ignition parts.
Was coming home from white rose centre down m62 with my g/f in fast lane. Car was shakking like mad.
Posted 07 December 2004 - 09:26 AM
Oil temp unless it goes over 120-130 is not a problem usually.
Alex
Posted 07 December 2004 - 10:04 AM
droool
Alex.
Posted 08 December 2004 - 12:07 AM
Posted 08 December 2004 - 12:14 AM
as its the crownwheel and pinion that must be changed?
havent looked at any tech manuals yet
Posted 08 December 2004 - 12:25 AM
Once you have the lump out of the car you can change it fairly easily without splitting the engine and gearbox if you want to though.
Posted 08 December 2004 - 12:26 AM
Posted 08 December 2004 - 12:38 AM
i would love to cruise at motorway speeds without needing new ears every 3 miles
Posted 08 December 2004 - 12:51 AM
There's lots of options available for the FD though, check the parts books to find a good compromise and remember to change the speedo drive gears as well.
