Hi everyone
Does anyone know an easy-ish way of fitting a new crank oil seal?
got the clutch working now the oil seal has gone....... nice puddle of oil on the floor
:grin:
David
Clutch oil seal
nomininolife
, Dec 19 2004 03:48 PM
10 replies to this topic
Posted 19 December 2004 - 03:48 PM
Posted 19 December 2004 - 04:15 PM
Which end of the cramk?
Siggy
Siggy
Posted 19 December 2004 - 04:21 PM
the dreaded clutch end
Posted 19 December 2004 - 09:28 PM
It's easy so long as you have a nice sharp Snap-On oil seal pick and the clutch seal fitting sleeve/tool. The tool comes from Mini Spares, you put the sleeve over the primary gear to protect the seal from the splines, grease up the seal lip and slide it on, then put the tool in place and put the flywheel bolt back in. It winds the seal in to the correct depth and keeps it square. Then take the tool off and put the flywheel back on.
Posted 19 December 2004 - 09:51 PM
i'm not sure how much the tool costs but i would say it was worth it i tried fitting 2 seals without it and they both looked like they where seated correctlly, but 5 min with the engine running and another nice puddle of oil was underneath the car.
that engine needed other work doing on it, and i managed to gert hold of an unleaded engine so i cheated and cahnged engines, the iol seal was the iceing on the cake for that engine
but the job is simple, don't forget to drain the oil first
Posted 20 December 2004 - 08:16 AM
Thanks guys
I will have a look for the tool
Thanks again
David
:grin:
Thanks again
David
:grin:
Posted 20 December 2004 - 09:17 AM
They dont do it anymore will have to look elsewhere
Posted 20 December 2004 - 09:24 AM
thats abit of a bugger.
I had the garage replace mine when i had me new clutch put in.
Posted 20 December 2004 - 02:43 PM
Does anyone have this tool?
I cant seem to find one anywhere
I am going to try making one out of exhaust tubing but I will need dimensions
Any help is greatly appreciated
Regards
David
Regards
David
Posted 25 December 2004 - 09:47 PM
Are you sure that they don't do this tool anymore? Did you ask them or just check their (useless) website? Try other places, maybe Mini Mania ( I think they have just opened a place in Wales) since the tool is still on their website.
I do have this tool, and I can send it if you really need it but I am reluctant to trust it to the post (especially if it is NLA) as the sleeve is quite precisely machined with a nice surface finish to protect the seal lip and I try to keep it in nice condition. It really is nothing personal, I just don't trust couriers or the post not to destroy the thing.
It is a fairly heavy lump and posting it would cost a bit I would think.
Posted 26 December 2004 - 10:34 AM
Yes i have found it on the minimania site in america, although i have managed to hire one for the holiday from min-e-bitz in sheffield which has done the job brilliantly (inbetween the downpours) so now i have just got the starter to sort (stripped its threads as i took the nut off) and the vacuum pipe (which snapped as i caught it putting the rocker cover back on).
Regards
David
:grin:
Regards
David
:grin:
