if you want your mini to be famous please read.
marksmini
, Dec 21 2004 10:44 AM
23 replies to this topic
Posted 21 December 2004 - 10:44 AM
ok
we was going to be waiting till the new year for the site kick up the arse, but due to being in MINI WORLD this month, we are sorting it now.
right,
to go under the section called Feature minis.
i want,
a single pic of your mini, the best you have, and also a list of the spec of your mini as much as you can provide,
maybe in some case's for real power a rooling road copy maybe, but defo the pic and a fill spec list
It will be going into here
as you can see its dead in there,
so please tak your time to do this for us,
then next time we can conatc mini world and say we have taken on board whats been said and its sorted,
filled with info
so GO NOW.....
and reply
right,
i want,
filled with info
so GO NOW.....
and reply
Posted 21 December 2004 - 10:49 AM
heres mine
has had some more added to it now but... its a start
please note, yours dont have to be anything like that,
just a pic and a spec will do we can do the rest
Posted 21 December 2004 - 11:26 AM
I'll gladly post ine up, do you have a proforma ( word doc or sommit like that that can be filled in or even better and online form !! )
Posted 21 December 2004 - 12:29 PM
just type it up here online, then we can copy and paste it easy from here.
now thats a idea!!!!!
im sure we could work on that but later on once we have a new front web site design,
we have lots todo before that tho
top idea tho
top idea tho
Posted 21 December 2004 - 01:21 PM
Well in jan ill be getting a new camera from the sales as my other is broken, i will take some photos of what i have done and i hope my dash will be finished by then too.
Posted 21 December 2004 - 01:25 PM
only need one of the car its self, for the min
but we have plans for something more personal for each members build
well tell more lateron that one
Posted 21 December 2004 - 04:25 PM
I'll sort something out for the minus soon
Posted 21 December 2004 - 04:39 PM
is the server php / mysql enabled?
Just had afew ideas.....
Engine: Transplated 988cc Engine (99H Block), RC40 Stainless exhaust system (straight through pipe, single box centre exit), PiperX Cone Filter, Proformance HT Leads and Lucas Sports Coil
Suspension: Standard all round.
Brakes: Standard Drums all round painted silver
Wheels/Tyres: 10" wellars in diamond white. 165/70R10 tyres on rear and 145R10 tyres at front.
Bodywork: Diamond white in colour. Clear front lenses, chrome handles, wipers, bumpers, headlight rims, grill surround and wing aireal. 2 Black cooper stripes along bonnet.
Interior: Single clock dash, grey/blue city interior. Black door cards with black door furniture. 13" Momo Racing steering Wheel. Fitted switches for airhorns (located in boot) and UV lights under dash.
General: Waxyoil'd underside and interior floor.
ICE/Security: Jvc Headunit with Magnet 150w RMS 6x9's in rear shelf, Pioneer 10" Free Air sub powered by Longmill JL990 Amp.
Future Plans: Janurary 05 - Booked in for flipfront, solid mounts, A panels and service. Summer 05 - Respray in blue.
Posted 21 December 2004 - 06:07 PM
Mini Turbo. www.turbo-mini.com
Spec-
Engine- Block modified to Group “A” spec, four bolt billet centre main cap, undercrown cooling jets, group “A” head gasket, Carrillo forged steel con-rods, hardened & balanced crankshaft, Mahle low compression forged pistons, fully ported & gas-flowed big valve cylinder head, ARP uprated 11 head studs, Piper camshaft, vernier belt drive cam kit, 1.5 ratio roller tipped rockers, lightened billet steel flywheel and backplate, AP racing rally/race plate, grey diaphragm, billet actuator, in car adjustable boost, custom alloy intercooler, samco hoses,K+N air filter, Maniflow stainless exhaust, dump valve with uprated diaphragm, Aldon dizzy, Cooper “S” crank damper.
Transmission-
JKD straight cut drop gears {with roller bearing conversion}, JKD straight cut gearbox, Tran-X limited slip diff with 3.4-1 semi helical cw+p, uprated driveshafts.
Interior-
Cobra Monaco bucket seats, Rollcentre 6 point cage,4 point harnesses, extensive I.C.E including, Playstation, video, fridge etc, VDO white faced dials in custom dash, black headlining.
Suspension/Brakes-
Hi-lo’s, Spax dampers, rose jointed bottom arms, uprated tie bars, uprated subframe mounts, negative camber brackets.
Drilled/grooved discs, alloy 4 pots, Minifin drums, braided hoses, uprated linings.
Shell-
1986 Mini city, fully restored, deseamed, debumpered, rear arches tubbed.
How do you put a decent picture up ? :saywhat:
Spec-
Transmission-
Interior-
Suspension/Brakes-
Shell-
Posted 21 December 2004 - 08:44 PM
1988 jet black;
Owned since september 2004
Standard interior except steering drop bracket
LCB,
twinbox rc40,
k&n in modified air box,
AAM needle,
12" minilites on the front and 10" wellers on the rear,
de-stickerd and rusty!
Daily driver till i get round to sorting it.
LCB,
twinbox rc40,
AAM needle,
Posted 21 December 2004 - 09:01 PM
1976 mini pickup;
completely standard appart from the rust, now undergoing restoration.
New passenger side floor and cill, driverside cill, front bulkhead repaired, new inner a panels and outer a panels, wings and front panel, new driverside door skin and bonnet patchs, still needing rear valance, wheel archs and rear crossmember
I WILL finish in time in time for the nurburgring run... i hope.
Hope this helps
ps can suply higher res pictures if required
Hope this helps
Posted 21 December 2004 - 09:19 PM
Will gladly help anyone with a designed page if needed. PM me with full car details, photo and any requests you have.
Posted 21 December 2004 - 10:19 PM
Marksmini, i know you can put a little picture up, but how do you add a decent sized one ?
Phil. :grin:
Phil. :grin:
Posted 21 December 2004 - 10:28 PM
if your pic is already on the net right click the pic copy the address and paste it into your post useing the IMG button at the top of your post reply page next to http:// and @
think thats what you mean
Posted 22 December 2004 - 01:14 PM
Mini 30
Engine: Standard 998cc original engine with lumenition electronic ignition system fitted, with Maniflow straight through 1 3/4" exhaust. Lots of anodised and chrome bits.
Exterior: Chrome Cooper grille, Four spotlight kit (not shown in picture), Standard Arch Kit, 12 x 5 Mini light wheels, stainless steel overriders,
Interior: Standard Mini 30 interior with the following extras 3 Clock walnut dashboard, Corbeau Low back Bucket seats, Centre Console, Alloy handle set, under seat speaker board, Mountney leather steering wheel.
ICE: Blaupunkt CD Headunit powering 2 x 3 inch 90W speakers on the rear shelf and 2 x 6 inch 110 W speakers under seat.
Current State: Partial restoration started with a few panels replaced. Also two brand new Rover Side impact doors fitted.
Future plans: respray/finish restoration early 2005, 1330cc engine(currently being built) mid-late 2005
Please note not up to date photo... although this is pretty much how it is apart from different arches and some panels in red oxide(awaiting respray)
