Engine breather?
Posted 29 December 2004 - 12:47 PM
Should i worry about the white stuff? I shone a lift into the rocker cap, the rockers seem fine.
Its been low on oil for about a week, due to me getting oil from my dad, who's business gets it direct from a supplier. I use castrol gtx 10/40 if i remember correctly.
Posted 29 December 2004 - 03:12 PM
this normally happens when you have a head gasket start to go or has gone.
check you coolant reservoir for any similar signs, and remove your rocker cover and have a look you will see more than just looking in the oil filler cap.
Have you been loosing power or performance out of the car?
Do you know when the head gasket was last changed? sometimes people don't allways flush out the engine properlly after changing a headgasket and you can still have residual white froth in it which will come to an opening in the end..say a breather or your coolant reservoir
Posted 29 December 2004 - 03:42 PM
Siggy
Posted 29 December 2004 - 08:48 PM
Cant say when Head gasket was last changed, i bought the engine in augest and the guy said it was sound and was removed from a car afew months before.
Will take a better look tomorrow, but i have been short running and espically at night (coming home from g/f's n work etc...).
Cheers guys.
Posted 29 December 2004 - 10:37 PM
Are you losing water?
Siggy
Posted 29 December 2004 - 10:50 PM
Will check rocker in morning.
Posted 29 December 2004 - 11:09 PM
Clean the breather and give it some longer runs, not just round to Kanes and back
Siggy
Posted 29 December 2004 - 11:28 PM
I aint been on them short runs, i mean to freeport and featherstone/pontefract which is abit further.
Will clean it out tomorrow.
PS. Dave do u want the tear drop mounts?
Posted 29 December 2004 - 11:44 PM
Freeport and Ponti are only short runs
Yes I will have them, how much do you want?
Dave
Posted 29 December 2004 - 11:49 PM
Posted 29 December 2004 - 11:55 PM
Dave
Posted 29 December 2004 - 11:56 PM
Posted 30 December 2004 - 12:09 AM
Slap me if im wrong.
Posted 30 December 2004 - 12:14 AM
Posted 30 December 2004 - 12:28 PM
When engine cools i will check the water level and remove the rocker cover. Might go wash the car for a change now....lol....
