Here are some base setting for you to work from.
Front
camber 1.5'
castor 3'
Tracking paralell to toe in 30minutes
Rear
camber 1.5'
toe in 2mm, (1mm each side) lase alignment needed to get this equal each side
Just acquired a Z-Cars Mini
Pete649
, Jul 28 2007 10:04 AM
17 replies to this topic
#16
Posted 24 August 2007 - 04:28 PM
#17
Posted 24 August 2007 - 04:36 PM
Front
camber 1.5'
castor 3'
Rear
camber 1.5'
Is there no end to your knowledge??
Hilty :
#18
Posted 26 August 2007 - 09:53 AM
Front
camber 1.5'
castor 3'
Rear
camber 1.5'
Mark,
Many thanks for that. I will see what the current setup is and adjust accordingly. Checked the wheel offsets. It's running 6x13s on the front with ET +15 fitted with 175/50s and 7x13 on the rear with ET -7 again with 175/50s. So there may be some scope to change the front to 165 and maybe get some wheels with a bit more positive offset to move them back in a bit more. I'll be fitting a tubular front subframe first and take it from there.
