Hey everyone, I'm at the beachhouse now where I only got dial up internet so I can't really be on 24/7. I'll be here for a day and want to get the most done with my mini.
One problem that I'm having that's getting really annoying is that if I rev the car (over a few seconds, not "pumping" the pedal) up to what I'm guessing is around 4k rpm (no tach) or higher, and suddenly let go off the gas, the car dies... If I let go just that little bit more smoothly everything's fine.
Car doesn't die on idle (with no choke) and will sit quite happily forever (does vibrate quite a bit though :\). Mixture looks to be spot on according to the plugs...
Any ideas what's going on here?
Need Help Guys!!
Pavel
, Jan 15 2005 02:23 PM
2 replies to this topic
Posted 15 January 2005 - 02:23 PM
Posted 15 January 2005 - 02:50 PM
does it really matter?.....the chances of you revving it up with your foot on the clutch when driving the car would, i assume, be pretty slim!
if its very rough at tickover, perhaps your idle is set a little low, this could tie in with it stalling after revving it.
roughness at idle could also be your points gap being too big as well.
Posted 15 January 2005 - 03:18 PM
i hazard a gess that the timming mite be out but dont take my word for it
