Was cutting my front arches today to stop wheel rubbing, and after I cut it there's only about a cm left until the arch mounting holes!! (angle grinders aren't too accurate you see!)
I tried pressing on the panel a few times and couldn't really see a difference between where there was a lip or not... So is it really that necessary to bend up a lip?
I think I asked this before, but the search function seems to be letting me down today :\
Cutting front arches
Pavel
, Jan 15 2005 03:54 PM
6 replies to this topic
Posted 15 January 2005 - 03:54 PM
Posted 15 January 2005 - 04:25 PM
the lip is there to stop the wing slashing your tyres when the suspension is at full compression
Posted 15 January 2005 - 06:34 PM
I'll leave it then until I'm able to get my hands on some GP2s. Ill just put a hard door seal on the wing edge to prevent it from touching the wheel (although to be honest if it compresses that much I'm sure there will be more damage than just the tyre heh
Posted 15 January 2005 - 09:04 PM
this is relevant to me as im cutting mine tomorrow! lol rob told me that if you leave half an inch gap you should be ok, to be on the safe side ile get some of that door strip stuff!
Posted 15 January 2005 - 09:25 PM
To be on the safe side do the right thing and bend a lip at the end (i.e. don't cut as much as I did!) :wink:
Posted 15 January 2005 - 10:06 PM
ahh okie dokie then :grin:
Posted 16 January 2005 - 06:09 AM
the lip also provides a lot of strength to wheel arch on the wing
