If you have been reading my projects page, you will know i have fitted discs to my 1980 mini. I always thought it had 'single' brakes. But after discovering a wet patch, tracing back to this:
I am not sure. I have no idea what the black thing is called. I have had problems with my brakes for awhile now, so i want to know if this leaking could be the cause.
If it is split line brake setup, can i replace this with one from a 1986 mini (with discs)?
Also, if using split line brake setup, can i use the rear brake cylinders from the 1986 rear brakes, as one of mine is leaking (and i need to change studs for longer ones etc anyway)
Just to make clear, MY mini is a 1980 Mini City (originally fitted with drums allround)
Thanks guys.
